N/A Rear Bumper Extensions
Patch
Postby Patch » Tue Aug 07, 2018 10:54 am
Came across these if anyone is after some rear lip extensions. They are universal but they're a pretty good fit for the N/A rear bar (and cheap!). Not compatible with factory rear mudflaps.
https://www.aliexpress.com/item/2pcs-Un ... 4c4d7FluXB
You'll need the 52cm length option in Black or "Carbon Fibre" (use the 'colour' selection). Your colour choice might not matter though, I ordered black and got CF :?
This is with them mounted as far out as they'll go. There is a gap toward the back where the flat mounting surface ends.
I mounted mine so they didn't stick out as far. No gap at the back.
The extensions come with self tapping screws, but I used two screws with captive spring nuts/clip nuts, and two push clips per side that I had laying around. Heaps of room under the rear bar to mark out and drill. You can use the existing mudflap mounting hole, will need to drill 3 other holes each side.
ReeceCozaa
Re: N/A Rear Bumper Extensions
Postby ReeceCozaa » Tue Aug 07, 2018 4:54 pm
Not bad! Looks real nice bro, a unique add on for a lancer too!
We are all in it for the fun!
Postby Lancer1993 » Tue Aug 07, 2018 10:00 pm
It is different, not my style but different.
ReeceCozaa
Postby ReeceCozaa » Wed Aug 08, 2018 3:10 pm
Kinda reminds me of the OEM wrx ones
Patch
Postby Patch » Sun Nov 11, 2018 2:59 pm
Cracked out the spray gun and gave these a paint over the weekend. Bit less attention seeking than the CF print!
Rubbed them back with 600 grit paper until they were dull
Wiped clean with wax & grease remover
Applied a coat of flexible plastic primer
Applied a few coats of colour matched acrylic
Applied a few coats of acrylic clear
