Im new to the scene and have a few questions.
I have a small knowledge on cars and i am wondering if i need to do an engine swap for putting a turo in (when i get 1) and what would you recommend for the motor and turbo duo? thanks in advance, my lancer is a 08 VRX manual.
Re: Im new to the scene and have a few questions.
You don't need a new engine. Look at getting parts from a Ralliart owner who has done a turbo swap e.g. turbo, intercooler, piping, lines, etc. Where are you located? You'll also need to find a reputable shop to do the work and possibly tune it (?).
Also be aware that it's quite expensive to do and you'll be running low boost with power <= a stock Ralliart
Are you sure about that? Being a VRX, wouldn't the block be a 2.4L 4B12? It was my understanding that there was no straight forward 4B12 turbo upgrade path like the 4B11 to 4B11T conversion I think you were suggesting...rusko110 wrote:You don't need a new engine.
I'd recommend getting a good tune, and maybe do better than those 2L stock RAs anyway...
MY09 VRX one of these:
benyamin wrote:Being a VRX, wouldn't the block be a 2.4L 4B12?
2008 model year VRX is 2.0L. But there'd be less involved ways to turbo a 4B12 rather than having to switch back to a 4B11 if the RA/Evo bits didn't directly fit.
Easiest, cheapest and safest approach is to purchase a RalliArt complete with 2ltr turbo standard
Or depending on how deep your pocket is an EVO.
If you want a turbo, like sarusa said ^^... They're AWD too... The RA is a single-scroll turbo, the EVO X has a twin-scroll...
iirc, the internals weren't up to it in the 4B12...Patch wrote:...But there'd be less involved ways to turbo a 4B12 rather than having to switch back to a 4B11 if the RA/Evo bits didn't directly fit.
Was that built '08 an MY08 or MY09? 2.0L (4B11) or 2.4L (4B12)...?J.Smith98 wrote:...my lancer is a 08 VRX manual.
Just one thing to do first. Trust your not on L plates
sarusa wrote:Easiest, cheapest and safest approach is to purchase a RalliArt complete with 2ltr turbo standard
I'd second this, do light mods on your Lancer and save for a RA. Turbo goodness without the hassles of getting a conversion certified. Will probably cost less and be much safer (AWD) in the end.
- Quismiff
J.Smith98 wrote:I have a small knowledge on cars and i am wondering if i need to do an engine swap for putting a turo in (when i get 1) and what would you recommend for the motor and turbo duo? thanks in advance, my lancer is a 08 VRX manual.
Job done mate
2007 MY08 VR-X
- Mystique
Better off buying a manual Evo, that way you don't have the issue of the ticking time bomb of the SST.
Thanks for all the feedback and ill probably save for an evo.
