Fuse taps and dash cameras
lxlancer2014
Postby lxlancer2014 » Sun Sep 10, 2017 12:46 pm
So I puchased a dash cam fuse tap and a dash cam. This is the fuse tap kit http://www.ebay.com.au/itm/Original-Das ... 2749.l2649. The dash cam I have requires 5 volts and 1 amp. I noticed that the tap kit converts 12v to 5v at 1.5 amp. If I hook up the dash cam will it be recieving to much amperage or will it only draw the one amp and the other 500ma doesnt get used?
Thanks.
2014 Lancer LX 2.0 CVT
>Stock as a rock
Re: Fuse taps and dash cameras
Postby Lancer1993 » Sun Sep 10, 2017 1:06 pm
I bought something similar on eBay, still waiting for mine. Only difference is mine are full size USB female as my DC has GPS on the power lead so I need to plug in the other end that normally goes into a USB socket.
Postby bumblebee » Sun Sep 10, 2017 2:45 pm
lxlancer2014 wrote:So I puchased a dash cam fuse tap and a dash cam. This is the fuse tap kit http://www.ebay.com.au/itm/Original-Das ... 2749.l2649. The dash cam I have requires 5 volts and 1 amp. I noticed that the tap kit converts 12v to 5v at 1.5 amp. If I hook up the dash cam will it be recieving to much amperage or will it only draw the one amp and the other 500ma doesnt get used?
Thanks.
Correct
Doesnt matter the amperage is too high
If the convertor shoved out 12 amps and your device needs 1amp then there is 11amps left that can draw on it.so long as it puts out the correct voltage then your right as rain.
lxlancer2014
Postby lxlancer2014 » Sun Sep 10, 2017 2:58 pm
Thanks bublebee. Just hooked it up then and its working fine.
>Stock as a rock
Postby bumblebee » Sun Sep 10, 2017 3:28 pm
All good robin hood
Here to help
Return to “Electrical”
