LED Shed lights
LED Shed lights
I know this is a bit off topic but...
We have a tiny 2.4 x 4.8 meter shed with no mains power and I wanted to get an LED strip wired up with a small solar panel and battery but can't find anything off the shelf.
I have seen one from Bunnings but all the light is from one panel like this.
https://www.bunnings.com.au/solar-magic ... t_p4351882
My idea was to use a 3 meter (or so) lead of LED lights around the shed to spread out the light, it would be far better set up given the low roof line. The solar panel on the roof and a switch near the door or end of the lead.
Has anyone made anything like this with parts you can get at JayCar?
Re: LED Shed lights
You can get 20 meter 12v strip led off ebay.
You can get a solar panel off ebay a lot cheaper then Jaycar. When you get the strip led you will need to increase the length of the wire from the battery to the leds to get them to the roof of the shed. If you have no idea how to use a soldering iron your safest bet would be to use some "positap" plugs to lengthen the wires.you can buy those off ebay from a company in melbourne.
Two of those units from bunnings would be awesome. One in diagonally opposite corners of the shed
More projects to come
Re: LED Shed lights
bumblebee wrote:You can get 20 meter 12v strip led off ebay.
This means the lights only work during the day.
You can buy cheap shed lights with rechargable batteries already fitted and solar panel.
I have one and it works fine
Re: LED Shed lights
If you use the battery that was mentioned earlier in the conversation with the solar panel your a step closer to achieving your goal
The simpliest is to buy two of the bunnings units mentioned earlier
- Ronan.Butler11
Re: LED Shed lights
we have a harry potter cupboard (under the stairs hence name) and we just got an LED bar with batteries from bunnings, they last quite a while provided they arnt running 24/7 consistently. 3 years ours hasn't skipped a beat. it does cost a bit more than wiring an led strip like Aspir3 is talking about though, and depending on your ideal setup it might not give enough lighting area compared to strips around the ceiling of the shed
if you want a recommendation i can give you a link, used to work in that tiny ass corner of lights in bunnings, now i just deal with unqualified idiots trying to build half their house for under $20 at the other end of the store lol
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
Re: LED Shed lights
Thanks for the ideas, I was thinking of 2 of those light but aren't they more of a spot light? Last thing you want is a light are eye level in your eyes, The shed is maybe 2 meters at the peak of the roof and just over 1.8 at the sides.
I did get a mains powered LED kit from Aldi once with a remote and it works great in the house but needs mains. I'll have a poke around Bunnings over the weekend to see what they have.
Re: LED Shed lights
Hiw about a standard old "dolphin " torch?
Re: LED Shed lights
I have a 'head' light but want something a bit better.
Re: LED Shed lights
Got spot lights on ya car?
Drive ya car round and open the doors up on the shed and fire up the spotties
- Ronan.Butler11
Re: LED Shed lights
we point ours upward, bottom of the stairs reflects pretty well in the cupboard, so thats what we do, depends entirely on your shed, if its tin/colourbond the lights pointing upward would work, there are also some pretty good trigger lights now, as you open the shed a button on the light releases turning it on and vise versa.
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
Re: LED Shed lights
Pointing upwards to reflect is a great idea. Go nuts with the bunnings ones and get 4 and put one in each corner
Re: LED Shed lights
Yeah I might try that in the back corner and see how it goes.
Re: LED Shed lights
Nice one
Re: LED Shed lights
Its a start, not very bright but enough if I need to get something at night.
I do wonder if I can hack the unit and run some LED strips from it!
