I'm looking for a push switch so I can hook up a front parking camera.
Checked on eBay and found some but just wondering if there are any used ones around going cheap?
This needs to be a push switch to turn it on and off, not a push and hold switch like the ASC.
I'm on the Sunshine coast.
Mitsubishi Push Switch
Re: Mitsubishi Push Switch
Might also need the 3 switch 'floor' panel for behind the gear change.
So called some wreckers and one wanted $33 for the switch, I can get this one on eBay for same price brand new!
I bought this item from ebay 142400864101
If you do a search thru ebay on "mitsuibishi switch" you will find quite a few to choose from. Just remember about the max current they will handle thru the switch itself is about is 3 amp. When i wires up my 15 inch light bar to my lancer to save heartache i went hunting thru ebay and found a full plug and pray ADR complient wiring harness and used it with the switch and it works a treat
More projects to come
Mine is for a camera power so that shouldn't be an issue, will probably get one on eBay as the used price for a stock push switch from the wreckers is stupid. As for the switch panel they want more for the few I've seen on eBay compared to less than $20 at the dealer, yes that's still a bit steep for a bit of plastic but still the better option.
Waiting on the camera still to get here delivery is at least a week away at the earliest. So it might be a month before I get the bits together and fitted, assuming the camera will fit where I want it on the front grill dead center just below the number plate. Hope to get it all done before my birthday on the 23rd of July.
Nice. Look forward to seeing it all installed and how it all turned out for you
