Stop seat belt chime ????
gtirdoc
Postby gtirdoc » Thu May 25, 2017 5:23 pm
Hi Guys and Girls
please note I always put my seat belt on but when I put equipment on my drivers side the seat belt chime always alarms and is extremely annoying.
I have had quick search with out any luck on this matter so I am hoping to get some confirmation and clarity on this.
Under the drivers seat and the passenger seat there is two plugs, One black and one yellow, When you disconnect the black plug it turns off the seat belt chimes but does this interfere with the airbags been deployed???
Many thanks
Ronan.Butler11
Re: Stop seat belt chime ????
Postby Ronan.Butler11 » Thu May 25, 2017 6:22 pm
if your not consistently having passengers you could have the seat belt clicked in the whole time.
i did it for a while, then i just started aimlessly throwing stuff on the back seat instead lol
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
Postby himynameisdaniel » Thu May 25, 2017 8:59 pm
Yellow plug and sheathed cable should be airbags throughout the entire vehicle. careful with this. airbags are expensive.
The more practical solution would be to just google "seat belt alarm stopper". they are like 80 cents. and are quite popular. Especially in countries that seat belts are considered optional.
Do not buy the seat belt extender clip things. that disable the chime but still allow you to buckle a seat belt. You do not want to put your passengers life at risk for a part that could have questionable quality control.
K+N drop in
RA intake
SS 4-2-1 Headers
Whiteline Strut Brace
Whiteline Rear Sway Bar
Paddle Shifters
Merlinised
Postby lancerdarryl » Thu May 25, 2017 9:35 pm
Easy fix.....just put all your stuff on the backseat or the passenger floor.Don't unplug anything under the seat,this will disable the airbag and seat belt pre-tensioner and could result in serious injuries in the event of an accident.
Postby Lancer1993 » Thu May 25, 2017 9:44 pm
How heavy does something need to be on the seat for the alarm to sound?
I put stuff on the front seat also but it's much safer to put anything heavy on the floor, or in the boot!
Postby Mystique » Fri May 26, 2017 3:02 pm
Lancer1993 wrote:How heavy does something need to be on the seat for the alarm to sound?
Probably a good solid couple of kg's, mine whinges when I put heavy grocery bags on them, I usually just move them on to the floor.
Postby aspir3 » Fri May 26, 2017 6:45 pm
For safety reason everything should be secured in the car or boot.
To stop the chime put the passenger seat belt in. Problem solved
burfadel
Postby burfadel » Fri May 26, 2017 9:19 pm
If you have something on the passenger seat and have it clipped in, the airbags could go off in an accident. These will not be covered by insurance.
adamhumphrey
Postby adamhumphrey » Sat May 27, 2017 3:37 pm
You may be able to disable the chime within the etacs. Maybe if you can find someone with a cable and Etacs decoder they can try to disable it for you.
MY11 Evo X MR (2011-Current)
MY20 Asx GSR (2023-Current)
Postby aspir3 » Sat May 27, 2017 6:40 pm
adamhumphrey wrote:You may be able to disable the chime within the etacs. Maybe if you can find someone with a cable and Etacs decoder they can try to disable it for you.
I dont think this can be done.
Postby lancerdarryl » Sun May 28, 2017 1:00 pm
Any tampering with ANY safety system on your car is illegal and could result in a defect notice.Just put your stuff on the floor or in the back.
gtirdoc
Postby gtirdoc » Tue May 30, 2017 7:56 am
I found this onYouTube for Suburu, Does the lancer have the same or something similar ?
https://www.youtube.com/watch?v=G3OvUo-u1xY
adamhumphrey
Postby adamhumphrey » Wed May 31, 2017 6:57 am
Depending on the age of the ETACS module it may be able to be done there is an option that allows the changing of the passenger seat warning mode.
keats1379
Postby keats1379 » Sun Sep 17, 2017 10:41 pm
Around 3kg's I've found, I can set it off with a 3L of milk, but not a 2L :lol:
MY RIDE: Gold 2011 CJ Lancer SX Auto Sedan
Shoulda bought a manual :mrgreen:
Postby bumblebee » Mon Sep 18, 2017 6:39 am
Luke
Use the boot Luke
Return to “Electrical”
