Hi all
I'm looking at getting a 2012 onwards lancer ralliart sedan
Would anybody be able to measure their boot for me, especially the window to the front when you fold the seats down?
My main concern is to be able to fit my bike in the boot with the front wheel off and the rear seats folded.
Thanks very much!
Ralliart sedan boot size
Re: Ralliart sedan boot size
The boot is the same as the other CJs.
With the boot open it's at least 150cm from the window/bootlid edge to the front seats, maybe more depending how far forward you have them.
I have fitted my bike in the boot with the back seats folded down
I should add the the only exception is if you have a full size spare (less height), a rear strut brace or the battery relocated to the boot, so it might have these in the way but the length will be the same.
- squala
- Post Monster
The Ralliart sedan's boot is NOT as big as the NA's. It's actually more shallow due to the 4WD system.
To find out if your bike fits, it might be better to find someone who owns a Ralliart kind enough to let you test their boot.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
If the width of them is no different to NA. The bike will fit across the back seat with the front wheel off.
Thanks for the replies all!
I'm pretty keen to put it in the boot so it doesn't wreck the seats, so it's really the width and height of the window between the boot and back seat that matters.
I was of the understanding that the ralliart had a more limited boot because of the strut brace and AWD
