Replace Instrument Cluster
Re: Replace Instrument Cluster
i have been wanting to change mine since i bought my car, just out of interest is the cluster pretty much plug and play?
i dont need to do anything after plugging in?
im just in the process of finding an auto electrician here in Adelaide that can reprogram for me and once i do im going to be seriously looking at buying one.
Black 2010 VRX Lancer
Yes it's plug and play except for the odometer reading
Hardest part is taking the dash apart, but take your time and its not that hard.
- Ronan.Butler11
Lancer1993 wrote:Hardest part is taking the dash apart, but take your time and its not that hard.
agreed, 1st time tak your time, once you pick it up its simple,
heads up though, line up the air vents when putting back together, the amount of times ive taken them apart at work in the summer because i bloody forgot to line the runners up!!!
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
Hey Guys,
I'm looking to get a colour cluster and was hoping one of you might be able to help clear up something for me.
It seems the Outlander and ASX clusters are also compatible, right...?
Also, does your transmission type have to match whether it's a Outlander, ASX or Lancer replacement?
I've got my eye on a Lancer one (2014), but apparently it's off a manual. Mine's a CVT. Will that work...?
Cheers,
Ben
Cheers,
Ben
MY09 VRX one of these:
It doesn't matter about the transmission.
And yes the outlander and asx will fit and work.
The main thing is to find one with similar kilometres
- ReeceCozaa
Wait so you can reclock the odometer by a professional, lawfully?
We are all in it for the fun!
- Quismiff
ReeceCozaa wrote:Wait so you can reclock the odometer by a professional, lawfully?
someone up north had it done, bumblebee put them onto someone who did it for a reasonable fee... I'll find it and edit this post with link.
It was here...http://clubcj.net/viewtopic.php?f=5&t=19341&p=401507&hilit=cluster#p401507
2007 MY08 VR-X
Thanks guys. That's quite helpful.
I'll probably reprogram the EEPROM myself. I have the technology and I think in hex.
- ReeceCozaa
I would of thought some one would be able too, I mean Australia, well Sydney seems to get real stringet in ODO changing
I imagine there would be a legal defence if you didn't commit fraud. In most jurisdictions mens rea (the guilty mind) is required for conviction. But then IANAL, so what do I know... ¯\_(ツ)_/¯
- lancerdarryl
Bear in mind that when the odometer is changed by a dealer workshop there is a paper trail listing changes made,this is the only way to keep everything legal
benyamin wrote:It seems the Outlander and ASX clusters are also compatible, right...?
Just make sure its not a diesel, the rev counter will be topping out at 4k or so.
I found a guy to change the reading on mine, but I documented everything.
It is scary to think you could buy any compatible cluster, switch it over, run up the kays then switch back to the old one with low kays on it and its next to impossible to police. I got the cluster out in about 15 minutes.
And of course this is not limited to the CJ, any car of just about any age you could do this. Not sure with newer ones where the cluster is tired into the rest of the cars electronics so much more than even out CJs.
I just adjusted the odometer for a mate and noticed the VIN programmed into the EERPOM. So if you're changing your cluster it might be an idea to change the VIN to match otherwise it might get throw up an error code later on or get picked up by a dealer.
