Armrest 12v accessory wiring harness
Mooman
Postby Mooman » Sat Mar 19, 2016 12:13 pm
I'm trying to install a 12v accessory socket in the armrest like on higher spec models. I've ordered and installed the box and socket for the console but where I'm stuck is running power to it.
I tried to order the wiring harness (8548A008) but it doesn't seem available easily, online was no luck (Mitsubishi parts warehouse) and local dealer doesn't have a stock code (see item 10 in picture below).
I've searched online for pictures of the harness or at least which plug it fits into under the cup holders but so far no luck either. I'm currently awaiting a wreckers response if it is obtainable.
If I had to self wire what would be the best option? Run it in parallel off the front socket or build up my own harness?
If building my own harness are the plugs easily obtainable (trying to avoid splicing wires) ie. could I get one at Supercheap auto or even cut one off from another part of a wrecked car?
If anyone has a photo of that wire harness it would help.
Thanks for any replies.
Postby aspir3 » Sat Mar 19, 2016 2:57 pm
The easiest and best way is to splice it in near the hand brake where the wiring loom is. It's not hard to do. It will only take someone who knows what they are doing about 10 minutes
zedd82
Postby zedd82 » Tue Mar 22, 2016 1:28 pm
Just run a cable back to the socket in the dash and splice the wires into that.
Mooman
Postby Mooman » Tue Mar 22, 2016 4:04 pm
That's what I ended up doing, splicing into the front socket with a wire sourced from the socket in a wrecked car.
After looking at circuit diagrams etc. It seems the harness is part of the seat heater circuit and my car was missing the 12v wire at the plug under the armrest anyway.
Works well and clears up the front from splitters and wires getting in the way of gear selector and handbrake.
Postby Lancer1993 » Tue Mar 22, 2016 4:37 pm
I'll need to do something like this as I'm adding some US ports to the center, using the spot behind the gear change, hoping the wires are out of the way when traveling.
Return to “Electrical”
