Good ideas for reverse cameras,?
- wolfeey152
- Lancer ES/EX
So I'm looking at getting an aftermarket reverse cameras and i would like to know my options and your opinions on these
Has anyone had experience with the parkmate systems from jbhifi
The ones that clip over the mirror. Or would I be best getting the ones with the screen and mounting somehwere such as the visor or the area under the air con switches
Any ideas on other systems which might be good?
- wolfeey152
- Lancer ES/EX
I'm in the same boat but I figure save up for the HU then get a camera and better speakers/sub.
Can I ask why you need a camera, yes I know backing can be a pain in the CJ (and most modern cars) I'm still learning and I've been driving many years and had the CJ 6 months now.
Short of a new HU then your cheapest option might be one where the screen is part of the revers mirror or on the dash. As you may know they are on eBay for less than $50.
What I'm also wondering is how hard is it to get a stock CJ camera on the boot below the diamond? Or is it better to get an after market on that might work better?
- wolfeey152
- Lancer ES/EX
Well my main issue is my workplace where it can be very very tight and I've been needing to get people to guide my reverse as it's just too close pretty much all the people who own cars follow the same procedure or we face parking up the road and walking. I was tossing up between a camera or sensors but I don't trust aftermarket sensors. The idea now I guess would be to start saving for a HU but get a camera installed with one of those separate monitors until I have the money
And just personally I don't really like the oem camera I find it just looks out of place. The aftermarket ones depending on which one you get look nicer and less obvious
I went down this road once before. I dont have a touch screen HU either but this was all bought the cheapest from ebay. Tried to mount a 7" monitor into the sunvisors I bought off ebay.
Depending on the monitors weight, you may come into issues with the monitor staying up when not in use. Also depending how crafty you are. Would also be ok when its pulled down to view. Routing the wires wasnt to hard and mounted the camera on rear bumper above the licence plate. In the end I scrapped the sunvisor mounted screen when wedged it in the area behind/infront gear stick.
The camera was rubbish, kinda grainy but does the job with 170 degree fov. Not too bad for basic reversing up close as long as you keep using the same reference. All up was roughly $40-$50. But as Lancer1993 suggested best option to wait for HU with screen or if you really need to maybe give it a go.
Good luck.
Good luck.
- wolfeey152
- Lancer ES/EX
- zedd82
I used to have a camera similar to this one http://www.ebay.com.au/itm/221521408116 and then had a replacement mirror with a screen built into it, http://www.ebay.com.au/itm/131534011685. Replacement mirrors look heaps better than the cheap ones that clip over your existing mirror.
- wolfeey152
- Lancer ES/EX
zedd82 wrote:I used to have a camera similar to this one http://www.ebay.com.au/itm/221521408116 and then had a replacement mirror with a screen built into it, http://www.ebay.com.au/itm/131534011685. Replacement mirrors look heaps better than the cheap ones that clip over your existing mirror.
I quite like the mirror one. Was it difficult to install? And how hard to get the old mirror off
This one is a clip on type, much cheaper and doubles as a crash cam, might be worth looking into for just $78.
http://www.ebay.com.au/itm/4-3Inch-Dual ... 33a545907b
Lancer1993 wrote:This one is a clip on type, much cheaper and doubles as a crash cam, might be worth looking into for just $78. http://www.ebay.com.au/itm/4-3Inch-Dual ... 33a545907b
That looks pretty good - let me know how it turns out - for that price its not even bad if its crappy
- wolfeey152
- Lancer ES/EX
So if im correct. This one here just plugs into yiur accessory socket rather than needing to splice wires
