Chrome garishes where side repeaters used to be
Lofty
Postby Lofty » Thu Jul 16, 2015 11:23 pm
Does the chrome garish on the side of the front quarter panel (where the indicator used to be before it was moved to the mirrors) just pop out?
I want to plastidip it black. Or I might even chuck some smoked indicators in there (I know they won't be hooked up).
Postby Lancer1993 » Fri Jul 17, 2015 8:59 am
Sorry can't help but I'd just like to say it is a bit lazy by Mitsubishi to not even bother changing the panel to remove the hole for the indicators. Yes I know it means a whole new press for those panels but really after 7-8 years it's the least they could have done considering they have done bugger all to change the design of the CJ since 2007.
Sorry mini rant over.
Mark14
Postby Mark14 » Fri Jul 17, 2015 9:20 am
You don't need to take it out to plasti dip it. Just tape a square or rectangle around the chrome, leaving atleast 4cm from each edge of the chrome and plasti dip the entire square, which has the chrome inside it. Then after 5-6 layers of plasti dip, peel off the square around the chrome and it should naturally seperate, ie. none of the plasti dip on the chrome should come off. I did it myself, it's not very hard :)
