2nd gear scraping
wolfeey152
2nd gear scraping
Postby wolfeey152 » Tue Jul 14, 2015 7:36 am
So I've had this issue intermittently since I've had the car
But more so lately
When up shifting into second it makes a sort of scraping noise kind of like scraping a rock across concreteand the gear stick wants to stop. And the passengers Hear it. It doesn't do It once the car has been run for about half an hour and doesn't while downshifting. Still does it no matter how slow I change. And doesn't do it if the car isn't moving
Going to take it in for warranty i think. But where do I start making suggestions because it probably won't do it when I take it there for them to look at it, is it possibly my driving habits also?
Postby Lancer1993 » Tue Jul 14, 2015 7:55 am
More driving lessons :)
Just kidding, it might be a synco issue, have the same thing driving a small truck for work. It's much older than your CJ but going up into 4th is always an issue, every other gear is fine.
I'd take it in for a warranty check and see what they say.
wolfeey152
Postby wolfeey152 » Tue Jul 14, 2015 9:43 am
Alright that's what I'll do. If it's a synchro will they just replace that or will they put a new tranny in?
I might also add. There's no noise from the tranny itself. Just the stick as well as the feeling. And also that rarely when shifting out of first. It kind of pops out as I pull on it a little. Should I also look at my clutch adjustment? And linkages
Postby Lancer1993 » Tue Jul 14, 2015 1:51 pm
Just thinking it could be in the linkage under the gear lever, which is a relatively easy check and fix as just need to take out the center console to check it.
In my old coupe I was having gear change issues, got so bad I could not select 1st, thought I was up for a big expensive GB repair bill. Turned out a couple of bushes in the linkage were worn.
That said it was 15 year old at the time so many gear changes and loads older than you CJ.
Just tell them what is happening and they could check it out under warranty.
wolfeey152
Postby wolfeey152 » Fri Aug 07, 2015 9:05 pm
*update* so ive had the dealer look over the car properly and they couldn't recreate it. But I've managed to capture the noise on video it's normally that noise in the video with some slight feedback through the stick like it's hitting a shift fork or the guide walls or such. You can hear the noise it makes pretty clear. What do you guys think?
https://youtu.be/KXvoHVw6ptI
XTPN
Postby XTPN » Fri Aug 07, 2015 9:47 pm
Sounds normal to me
wolfeey152
Postby wolfeey152 » Sat Aug 08, 2015 8:09 am
XTPN wrote:Sounds normal to me
Well yeah I keep thinking it may just be normal.it's like a big clunk with feedback through the stick l. But only on second? And not every shift either? That's why I worry Does your cj also get that same tapping or whatever you wanna call it as well as the stick feeling as though its rubbing against something?
denzza
Postby denzza » Sat Aug 08, 2015 11:22 am
sounds like grinding to me.
Does it happen at certain revs ? is the car cold when it happens ? does it do it when its warmed up ?
and how much kms on the car ?
FULL EVO X TURBO SETUP
BC RACING BR COILOVERS
wolfeey152
Postby wolfeey152 » Sat Aug 08, 2015 12:02 pm
3500 km on the car. Brand new. Does it about 90% of the time. Regardless of how warm/cold the car is. Isn't rev dependant. But only happens on upshifts. Can downshifted perfectly fine
Double clutching doesn't work either
denzza
Postby denzza » Sun Aug 09, 2015 9:33 pm
Best answer anyone is going to give you.
Go back to Mitsubishi and they will fix anything wrong with it :) WARRANTY LIFE BABY :D
Let us know what the issue was !
wolfeey152
Postby wolfeey152 » Sun Aug 09, 2015 9:36 pm
I've had it in to them and they say they can't even reproduce it
But then anyone who I let drive it can reproduce it under normal driving. Thats why I took a video :/ it's starting to annoy me now actually lol :p
denzza
Postby denzza » Sun Aug 09, 2015 9:41 pm
Go back again and tell them to drive it again. If it doesnt happen, you drive them. Go to a different dealer :D
wolfeey152
Postby wolfeey152 » Sun Aug 09, 2015 9:45 pm
I've got a cam hooked on my centre console atm and every time I stop I turn it on to record it. I'm going to get a few more instances and I'll go back. And then if no results ill be going elsewhere. Nepean motor group has been quite sub par with my car. so yeah ill be going down that path probably. :)
