WTB:Rockford fosgate sub enclosure
wolfeey152
Postby wolfeey152 » Wed Jun 24, 2015 3:25 pm
Hey all. I'm trying to track down the sub enclosure from a Rockford fosgate sub
Preferred to be empty as I'm installing my own system
Hopefully someone here has one :)
Thanks guys
Shaun Patterson
Postby Shaun Patterson » Wed Jun 24, 2015 4:43 pm
they are so thin, cant fit much of a sub in them, just but in a box, you will be much for satisfied with the performance, i am running dual t1 RF subs and its sounds amazing, could never fit them in a tiny box
wolfeey152
Postby wolfeey152 » Wed Jun 24, 2015 8:39 pm
Shaun Patterson wrote:they are so thin, cant fit much of a sub in them, just but in a box, you will be much for satisfied with the performance, i am running dual t1 RF subs and its sounds amazing, could never fit them in a tiny box
Might be worth doing. What is it worth getting a custom box made to fit off to the side? I'm really not after something great. Just something to make the lows a bit more pronounced compared to just the 4 speaker stock system
Postby Lancer1993 » Wed Jun 24, 2015 10:24 pm
Someone has a system on eBay with speakers and the amp, not sure if you can just add it to a stock setup?
http://www.ebay.com.au/itm/291499685223 ... EBIDX%3AIT
Shaun Patterson
Postby Shaun Patterson » Thu Jun 25, 2015 2:09 pm
you could go that way, easier to just go to autobarn and get a square box, you get get some really slim ones
Postby Lancer1993 » Thu Jun 25, 2015 2:36 pm
I have asked before but how easy is it to install the stock sub/amp as I listed above or is there more wiring needed for most Lancers?
wolfeey152
Postby wolfeey152 » Fri Jun 26, 2015 2:00 pm
Lancer1993 wrote:I have asked before but how easy is it to install the stock sub/amp as I listed above or is there more wiring needed for most Lancers?
yeah I would also like to know. Because if it works then I'll just grab the whole kit. The idea otherwise is to just get an aftermarket amp. All I really want the box for is because it fits so nicely in the car
Return to “Buying & Trading”
