4b11T swap, or sell up my orange and buy a ralliart?
- Shaun Patterson
what do u guys think, which is more ecomonical money wise, which would offer more? ect.
bearing n mind i just spent 8k on my VRX..
Honestly, it is all up to you.
As a 4B11T swap owner. It wasnt done on a budget and just wanted to get it done. Its a good learning curve. But in saying that, the 4B11t motor isnt a straight fit. Theres minor things that have to be changed and is around the 6k mark. Would need a shop to do it. But again, its your car. People say sell it and buy an RA because its easier and more "reliable" but again. Its just another RA liek everyone elses. Choice is purely upto you
FULL EVO X TURBO SETUP
BC RACING BR COILOVERS
- Mystique
Maybe you should have thought about that before spending 8K doing the makeover? You could have put that towards a Ralliart?
IMO the biggest issue with any mechanical mods which involve transplanting an engine and drive train into a car not sold with them is the engineering paperwork. Getting it legal and running as it would have come out of the factory, but if you have the time and can do the work it might be the way to go.
That said it might end up far cheaper to find a good RA and just paint that orange and do other mods to it and know the mechanics are legal and working.
JMHO
JMHO
- Shaun Patterson
Speedie wrote:Dont you have access to an evo wreck? You could get it done at a good price
Evo Wreck wasnt as clean as my friend said it has some pretty bad damage..
yeah its a hard decision, i started this project before the P plater law changed. now i can drive a ralliart, if i had of known i wouldnt have spent all the money i did, but no regrets
- squala
- Post Monster
Mystique wrote:Maybe you should have thought about that before spending 8K doing the makeover? You could have put that towards a Ralliart?
Now on to some helpful advice...
Upgrading to a Ralliart is the much more sensible choice. The only reason you'd want the 4B11T swap is if you have a manual and stand by it. I suggest you test the SST and see how good it is. Flash the S-Sport mode and you'll feel it kick almost like a stick, but without bogging down when changing gears. Flicking the paddles will shift gears more quickly than your left hand and foot can ever muster, no matter how well you try.
Also bear in mind that anything over 300 hp (~225 kW) in a FWD chassis is not a good recipe. Unless the chassis is as sophisticated as the previous Focus RS, then you're certainly better off with 4WD.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
