- mrlancealot
Re: What did you do on your car today?
@Lancer1993 You are on stock speakers?
08 CJ Lancer ES, VR booty, VRX wheels
* Adj Strut Bar
* K&N Air Panel filter
* Adj Strut Bar
Lancer1993 wrote:Fixed this...
Yes I noticed yesterday that the wiring grummet was not sealed, not good on the leading edge of the back door. I don't think any water got in.
Tried pulling it out but had to take the door trim off, easier than I thought, 3 screws!
Fixed it.
And trim back on, could have gone to the repair place but Friday afternoon before a long weekend?
Good to see panel beaters attention to detail remain top notch
Today I continued to work on my car. Coming the week ahead i'll be painting it (myself (so not expecting the greatest outcome considering I've never painted a car in my life)).
Look out for my thread coming soon on my progress from start to finish.
No longer own a lancer, Fairwell.
mrlancealot wrote:@Lancer1993 You are on stock speakers?
Yeah, not seen the need to replace them.
But now I know how easy they are to get to I'll consider it if i find a good deal on them.
How easy are they to wire up, just plug in or do you need to solder?
Lancer1993 wrote:mrlancealot wrote:@Lancer1993 You are on stock speakers?
Hey Craig,
you can get these https://www.ebay.com.au/itm/Aerpro-APS3 ... 2749.l2649
it will allow you to plug any speaker into the lancer's wiring.
These https://www.ebay.com.au/itm/AERPRO-APS3 ... ctupt=true
will allow you to easily mount aftermarket speakers.
Cheers Pete
Thanks for the dangerous post LOL
Any extra money right now is going towards new brakes at the next service.
- mrlancealot
@Lancer1993 I did it with this method (pliers and solder):
https://youtu.be/eeHb3qnjFQY?t=108
No need to buy *any* adapters.
Edit: Actually, I improved on his method by not cutting the adapter. Just solder about 5-10cm of speaker cables from new speaker to the speaker frame. So the speaker plug from the door just plugs straight back into the frame.
Ps. It will probably won't fit all speaker sizes. But I was able to install these perfectly: Pioneer TSF-1634R 6.5"
* Adj Strut Bar
* Adj Strut Bar
I mentioned the adaptor in case Craig doesn't want to destroy the original speakers like i did in my CH which now i have to buy speakers to replace my Type R's when i move them to my CJ next week.
BTW total cost of the adaptors is less the $60 for all four doors.
So now he has both options.
- mrlancealot
All good man, wasn't dissing. And yes, the hack method does involve destroying the old speakers. Which you may or may not want to do.
* Adj Strut Bar
* Adj Strut Bar
Just need someone to buy me the speakers now
- Quismiff
When I got my car back from the workshop, after the sauce jars were dropped on it, and the bonnet was resprayed, the LHS washer nozzle has since popped out as the paint is so thick, and the weather strips along the roof the little end caps are broken and loose in there at each end and half the clips that hold them down are broken or missing, all noticed (clips) or happened (nozzle) after the workmanship grace period to get it remedied under "warranty". So remember that all their dodgy workmanship may not be immediately obvious.
2007 MY08 VR-X
I should have washed it earlier but with the wet weather and new paint I didn't want to mess it up. Hand washing is a really good practice as you often find problems like scratches and small dents you never noticed with day to day use.
- Quismiff
finally fitted my Dash Cams, Uniden iGo 50r 1080p front 720p rear, all cables fitted tidely behind panels and hood lining, has a reserve battery so when fully charged it has 15 mins of backup, only takes a 32gb card, has GPS logging, and I finally have a use for the cigarette socket in the centre console
Also had new tyres fitted on Friday by RACV, had the option to do wheel alignment, but its so far out that they're refunding me to get it done by a workshop.
2007 MY08 VR-X
- lancer2014
- Lancer ES/EX
washed and reconnected with hydrosilex
evo x turbo kit
RRM crank pulley
Magnaflow cat back 2.5
Tein Flex Z Coilovers
MR BBS Rims
RRM crank pulley
MR BBS Rims
Got the plugs to keep dust out of the USB power
Oh and made my CJ more legal and replaced the black 'reflector' lights with these red ones that look more stock. Didn't take the bumper off and OMG what a pain in the arm, but yes it can be done with the right tools!
