******PLEASE DO NOT DELETE OR EDIT YOUR POSTS BEFORE THIS ONE*******
AS YOU'LL BREAK THE THREAD AGAIN....
problem with adjustable air vents
- The X
Mine are not 100% but I haven't had an issue as the AC works fine and I just adjust the temp when I need more air flow.
My issue is the passenger side vent is pushed in a little bit.
The problem is the gap means the control vent can dislodge from the opening mechanism inside the vent.
Just need to how you safely remove the vent to try and fix it. I assume the dash wide trim that runs under the stereo is removed, done that before.
But then what? Do I just yank at it from the bottom edge are are there more screws to remove?
Users browsing this forum: No registered users and 86 guests
