Lancer Bulb List!
D
Postby D » Fri Jul 04, 2014 9:11 pm
byzon3 wrote:Ow good like an easy swap.. if you randomly remember what type of bulb very keen to know. also with your set, does the light stay on all the time or just when the afs is active ie turning?
Just when afs is active Hope this helps,
ended up getting out my spare set and having a little play, basically you
1. remove the dust cover
2. Unplug the corresponding connection
3. Twist globe mount (counter clockwise from memory)
4. Remove/replace bulb
the last couple pics are them on (the red is just a painted shield note:it does not effect the light output from the projector, and is only visible at applicable angles)
Sorry for the iPad spec pics :p and the dirty car, hope this helps
ROTM WINNER SEPT 2014
byzon3
Postby byzon3 » Thu Jul 10, 2014 8:29 pm
Dion thanks heaps for that, very helpful
I have ordered them but the ad said they were 1156's *facepalm*
so there not the right ones but I have now ordered h11 as per your pics !
thanks for the help!
Postby Lancer1993 » Sun Jun 28, 2015 5:16 pm
I'm such an idiot, didn't realize I needed 2 globes for the CJ, separate ones for low and high beams. Which is a shame as it almost doubles the cost at around $150 for a set of 4. Thats a big chunk towards whole new head light fittings, maybe with built in DRLs and angel eyes.
I know all the numbers but in the real world is there a lot of difference between the different after market globes?
Also for high way travel is it better to just upgrade the high beam or do you need to do all of them at once?
wolfeey152
Postby wolfeey152 » Tue Jul 21, 2015 7:22 pm
Sp I'd like to mention something I noticed today. I changed my dome light today and purchased some 12v 5w LEDs and on changing them noticed in the manual and also on the enclosure that it had listed that I need a12v8w globes? This is confusing. I have a my15 lancer. Nonetheless the 5w ones work just seem quite dull
Bigdamos
Postby Bigdamos » Wed Jul 22, 2015 4:39 pm
I just bought $10 LED ones from Supercheap Auto that were a 31mm festoon bulb and they seemed to work fine in mine, didn't really check any of the specs just went looking for 31mm festoon ones. They are definitely brighter than the stock ones.
Postby Lancer1993 » Thu Jul 23, 2015 7:43 am
You can get the same thing much cheaper on eBay...
Speaking of, are these any good for the reversing lights as an upgrade?
http://www.ebay.com.au/itm/2x-T20-7443- ... 4ab96d5f18
MitchArbee
Postby MitchArbee » Wed Oct 28, 2015 1:49 pm
Can anyone post pics of what their tail/brake lights look like with LED equivalents in there (preferably in stock housing)?
Keen to buy, but only if they look decent.
My ride: [bold] 2015 ES Sport [/bold]
Postby Lancer1993 » Wed Mar 09, 2016 5:28 pm
Just wondering which brand of head light bulb do others recommend?
SCA has Phillips and Narva in various models of brightness.
Over all the Phillips cost a bit more but does that mean they are better?
I was looking at the Arctic Blue ones with the HB3 at $71.49 and $64.95 for the HB4.
Zaphod
Postby Zaphod » Wed Mar 09, 2016 5:51 pm
Both are good.
I'm not helping am I... :-)
Postby Lancer1993 » Wed Mar 09, 2016 6:22 pm
I'm more interested in knowing which is the better brightness to get for HWY use, do the Arctic Blue ones actually have 50% more light?
Postby Lancer1993 » Thu Mar 10, 2016 7:28 pm
Bumped :)
So which ones do you guys have?
Postby Lancer1993 » Fri Mar 25, 2016 5:42 pm
SCA has the Philips WhiteVision globes for $40 each pair for the HB3 and HB4. They are 4100k and the same wattage as the stock ones.
Will they make a difference to the amount of light I get or just change the color closer to white, do I need more powerful ones for more light?
luke_1993
Postby luke_1993 » Fri Mar 25, 2016 7:51 pm
id like to know about this as well? is it worth getting the WhiteVision for $40 or get crystal or diamond.
Mooman
Postby Mooman » Fri Mar 25, 2016 8:03 pm
I have the Philips Xtreme vision bulbs (+100% 3350K) in the low beam light only (HB4) and to be honest notice little real difference, there does seem to be more light to the sides and a little whiter, but about the same forward.
The thing to remember with lights is that yellower light actually projects further but white light gives better colour representation so appears brighter. For highway driving you can mostly use high beams (when permitted) which project fairly well with the stock bulbs.
Also the higher kelvin the light usually the shorter life it will have as it has to burn brighter. And if the white light is gained by using a blue filter then it will give even less light overall as intensity is lost to the filter, which the Whitevision and Crystal vision blubs both have.
So white mostly for the look, stock or warmer colour for distance.
