LED SMD replacements for interior lights
Blakey
Re: best fit you
Postby Blakey » Thu Apr 15, 2010 12:35 pm
Goodspeed98 wrote:actually you can get a adaptor which can fix the problem ,for the current which is the rated current ,so if you want to replace it with led lights ,an adaptor would help you a lot ,you can take led SMD 3528 which is 0.08W for each led lights ,means you can take the length as you want and the led stripis also can cuttable .
a site may be much better help you
Http://www.ledlightsworld.com/
hope this works ,
regards
i guess you must work for that company. heard you quote the place like 20 times(exageration) and i take it you mean that you can get a light fitting adapter so that you can basically plug a positive and a negative wire, that you can then take out to LED strips. i think is what you are trying to say. its just as easy to to do the same thing cutting into the wire from behind then you can hide your wires and you dont have to have wires coming out of your light socket.
milobob
Postby milobob » Sat Apr 24, 2010 6:51 pm
So I've actually put in a 16-LED SMD into the sportback's boot light - lights it up very well. However, due to the terminals (-ve and +ve) I've had to orientate the SMD towards the side wall (as the SMD is physically too large to sit flat).
My suggestion is that you get a 9-LED-SMD so you can orientate it properly.
Postby sleeper » Fri May 28, 2010 9:00 am
ok guys, i just ordered 4 31f8smd1p bulbs from brightlights as there is no stuffing about with wiring, i just hope they are bright enough to read by, we will see, oh, and blue is the colour.
Postby sleeper » Fri May 28, 2010 5:28 pm
ryan, these are blue and have 8 smd`s inside :)
dannyboi
Postby dannyboi » Sun Aug 22, 2010 10:08 pm
With regards to the power rating for the map and centre dome lights, what wattage should I be looking at?
Really don't want to affect the plastic, as mentioned at the start of this thread.
I want to get my hands on some SMDS off ebay. I'm thinking
1) 6 SMD LEDs for the map lights
2) 16 SMD LEDs for the dome light and the one in the boot
Postby Mitch » Mon Aug 23, 2010 8:21 pm
i have one 61SMD LED light for my Dome light and if that one works out alright i will get one for my boot
i have 2 x 31mm SMD LED Car Festoon Dome Light 3175 3021 White for my front map reading lights now just wanting to get one for my boot aswell
dannyboi
Postby dannyboi » Fri Aug 27, 2010 7:53 pm
Hoges wrote:Danny, the LED's wont be on long enough to cause any affect to the plastic, as they are very low wattage they dont heat up nearly as much as the standard incandescent, they burn after a few seconds being on. LEDs wont.
I wouldnt bother looking at the power rating of the LED festoons as it is negligable, Just look for brightness and what colour you like
Thanks for the heads up then. It's time to ebay...
dannyboi
Postby dannyboi » Thu Sep 02, 2010 8:51 pm
Silly question, but what size festoon should I be getting for the map, dome and boot lights?
dannyboi
Postby The X » Thu Sep 02, 2010 8:56 pm
dannyboi wrote:Silly question, but what size festoon should I be getting for the map, dome and boot lights?
You're after the bulb list thread.... :)
http://clubcj.net/viewtopic.php?t=224
Also have look at page 1 of this threead
