Lancer Bulb List!
ZERO COOL
Lancer Bulb List!
Postby ZERO COOL » Thu Oct 30, 2008 3:41 pm
Front of car:
Front turn signal light: 21watts bulb: WY21W
Head light, high beam: 60watts bulb: 9005 HB3
Head light, low beam: (halogen bulb) 51watts bulb: 9006 HB4
front foglight: 55watts bulb: H11
Front side marker and parking light: 5watts bulb: WY5W 194
Side turn signal light: 5watts bulb: W5W 195
REAR of car:
High mounted stop light: ---watts bulb: -----
License plate: 5watts bulb: W5W 194
back up light: 21watts bulb: 7440
tail light: 5watts bulb: W5W 194
tail and stop light: 21/5watts bulb 7443
rear turn signal: 21watts bulb: 7440
rear sidemarker: 5watts bulb: W5W 194
INSIDE CAR
Trunk Bulb: A12V5W x 28mm (festoon)
Dome Bulb: A12V5W x 31mm (festoon)
MARS HEADLIGHTS:
Low Beam: H7
High Beam: H1
Parkers are built in, rest of the lights are the same as above
OEM PROJECTORS:
Low Beam: OSRAM d2s
Ozie
Postby Ozie » Thu Oct 30, 2008 4:21 pm
your the best ZERO, Nice work. great info again!!!
jamez707
Postby jamez707 » Thu Oct 30, 2008 4:59 pm
thanks for the great info
Red Tail Light Brigade Member #3 - ClubCJ Lifetime Member #007
JAMEZ THE TAGMASTER
ZERO COOL
Postby ZERO COOL » Thu Oct 30, 2008 5:44 pm
No problem guys anytime.
momo
Postby momo » Fri Oct 31, 2008 2:54 pm
thanks for the info! =D
Tarquin
Re: Lancer Bulb List!
Postby Tarquin » Sat Nov 01, 2008 2:00 am
ZERO COOL wrote:Side turn signal light: 5watts bulb: W5W 195
I've tried to change these for SilverVision style lights (to get rid of the Orange smudge), but in the process found that the side lights are a sealing unit, so they are difficult to replace....
Manual says to go to Mitsubishi for replacement, so I'd suggest they would charge for a whole new unit rather than a bulb....
I'll going to try and find some replacements either at a wreckers or on ebay, so that I can crack them open [bake them perhaps] to get into them to remove that orange cap inside and use a silver bulb instead...
- CCJ Premium Member #0015.
Tarq's Paintshop
Spacetingle
Postby Spacetingle » Tue Nov 04, 2008 3:14 pm
cool!!!
ImageSpacetingle - Under the Milky Way tonight
gtsrebel_210
Postby gtsrebel_210 » Wed Nov 05, 2008 7:07 am
just ordered my front signal turn lights. dont really like that orange bulb in the front. hopefully get them in the next 2-3 days. great info!
Tarquin
Postby Tarquin » Tue Nov 11, 2008 9:51 pm
I hope you mean the main front turn lights and not the sides??
Side turn lamps can't be changed without damage to unit....
FYI 'T20' style bulbs do not fit in this type of connection - believe me I have tried... it has to be the WY21W
I've done this to mine already and it looks sweet..... I'll see if I can get some pics up to show you the difference with the front turn signals....
You can still see some amber/yellow parts at some angles, but it is very pale in colour when you compare a normal amber bulb in there....
Tarq's Paintshop
dumb&
Postby dumb& » Thu Apr 02, 2009 2:45 pm
So do our cars take HB4/HB3's or H4/H3's?
Tarquin
Postby Tarquin » Thu Apr 02, 2009 11:10 pm
daveee wrote:So do our cars take HB4/HB3's or H4/H3's?
ZERO COOL wrote:Head light, high beam: 60watts bulb: 9005 HB3
High Beams are HB3's... Low Beams are HB4's.... aka 9005's & 9006's :P
Not the same as H4/H3's... Mount shapes and angles are different
Tarq's Paintshop
ads18x
Postby ads18x » Sat Apr 11, 2009 10:36 pm
So is it possible to replace all the bulbs, interior, brake, reverse, indicators etc, with those LED equivilents other than the side indicators and obviously the headlamps?
ANDROS
Postby ANDROS » Wed Apr 15, 2009 3:57 pm
what are the map light bulbs?
___________________________________________________
ads18x
Postby ads18x » Sat Apr 25, 2009 6:19 pm
in the manual the map lights are the same wattage as the dome light so i presume they are the same
RedCanuck
Postby RedCanuck » Tue Jun 30, 2009 11:54 am
Hey Zero Cool, thanks for the detailed info, most helpful.
BertMans-Red-Rocket
Users browsing this forum: No registered users and 77 guests
