Philips 'BlueVision' vs 'Crystal Vision' vs 'Diamond Vision'
jmon5
Postby jmon5 » Mon Sep 16, 2013 10:18 am
ian wrote:thanks! gonna get the 4300k then noob question: How do you change them?lol any link to DIY or get someone to change them?
I have the diamond vision bulbs because its very hard to tell whats compliant for headlights nowadays and I do like the blue tint of it.
Theres so many people with such bulbs on their cars and with HID's standard on most cars nowadays its make it even harder to tell what is actually legal.
Plus you'll have the occasional car with HID's installed when its not supposed to and then blind you when approaching. Please don't do this :P
Getting them installed is relatively easy. its just a quick plug and play. Instructions on how to remove them should be in your car manual
Seffy
Postby Seffy » Mon Sep 16, 2013 11:11 am
Just curious, how much is it for a pair of these bulbs? ;;'
BZC-45S
Postby BZC-45S » Mon Sep 16, 2013 11:46 am
Genuine Philips automotive headlight bulbs are about as expensive as headlight incandescent bulbs go. Brick and motar retailer typically $60-80. Online sellers $40-50. Low-mid $30s is about as cheap as you're likely to source them when all the stars align (eg. online seller having a sale, with free shipping to Aus, etc). Anything coming out of Asia you can presume is non genuine.
Seffy
Postby Seffy » Mon Sep 16, 2013 11:49 am
BZC-45S wrote:Genuine Philips automotive headlight bulbs are about as expensive as headlight incandescent bulbs go. Brick and motar retailer typically $60-80. Online sellers $40-50. Low-mid $30s is about as cheap as youre likely to source them when all the stars align (eg. online seller having a sale, with free shipping to Aus, etc). Anything coming out of Asia you can presume is non genuine.
They don't seem too badly priced. Thanks Chi. :D
Might just grab a pair out of a local unless I find some online genuine sales.
Postby SIX » Mon Sep 16, 2013 1:07 pm
citris.87 wrote:[quote:54bcade11c=SIX]legal limit in SA and I think it would be the same every where else is 4200kw , hense why the narva intense is legal but the crystal visions are not because they are 4300 kw , but its too hard for police to tell the difference[/quote:54bcade11c] 4300kW those are some powerful lights lol. I wasnt aware that anything over 4200 Kelvin was illegal, thats a bit stupid, is it to do with the fact that they emit less light? or too much? or simply the colour, which, looks white at 5000.
it do to with the reflection from the head light has on the driver on the on coming traffic hense why HID on reflector lights are illegal because theoretically the refection is as bad if not worse than driving around with your high beams on with reflector lamps .... its not illegal on projector lights as they concentrate the light on a certain area reflector lights spread the light every where hense why over 4200kw is illegal on reflector lights
alterego13
Postby alterego13 » Mon Sep 16, 2013 11:13 pm
Seffy wrote:Just curious, how much is it for a pair of these bulbs? ;;
www.powerbulbs.com/au is where i bought mine from. They had a 20% off code at that time so it worked out cheaper. Right now they have a 10% off code that works 'RLKHQ1883', there might be other discount codes floating around. And yes you get 2x Matching Parker lights free.
Tarquin
Postby Tarquin » Tue Sep 17, 2013 12:02 pm
4200-4500K is the key to providing you with a good output strength to be usable and a 'white' light that is not yellow or blue....
I have used all of those x3 type that have been listed, but I currently have PIAA 4500K. They are the best I have ever used - really bright, and really white. About $60-90 depending on where you get them.
I also use 2500K yellow lamps for my Foggies - the best to actually get through and under the fog
- CCJ Premium Member #0015.
Tarq's Paintshop
ian
Postby ian » Sun Sep 22, 2013 2:42 am
ok guys done with my low beam and parking lights
next is high beam and those yellow number plates light which i would like to change to white.
Anyone know what type our lancers have for high beam and for the number plate lights?
alterego13
Postby alterego13 » Sun Sep 22, 2013 2:49 am
Before you get flamed for not using the search bar/forum index...
http://clubcj.net/viewtopic.php?t=224 has all the lighting parts that our lancers take.
Hope this helps :)
ian
Postby ian » Sun Sep 22, 2013 2:57 am
oops sorry,
that is quite on old tread (2008) is it still the same to 2012?
Fizzlefuzzle
Postby Fizzlefuzzle » Sun Sep 22, 2013 10:14 am
T10 for number plate lights
Tarquin
Postby Tarquin » Sun Sep 22, 2013 6:02 pm
ian wrote:oops sorry, that is quite on old tread (2008) is it still the same to 2012?
Light types have not changed for the CJ model - still valid.
Tarq's Paintshop
