tow bar for lancer CJ or Ralliart
Until Andrew mentioned it I did not think they would have different part number..for eg if you needed a new TCU i can understand why the part numbers would be different but for other mechanical stuff (clutch packs) shouldnt it be the same?
i would say so.
i always thought just the software would be different
hence why you can make a ra have s-sport
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
DBA Extreme Pads
Tein S Tech Springs
- zedd82
Well Mitsubishi don't sell just the gears etc. to go in them, they only sell them as a whole unit except the clutches, so they would have to be different part numbers if you think about it to distinguish between the RA and Evo boxes.
Pretty simple really.
Well I am confused they must be the same box surely and different software ????????
Re:
gman90 wrote:After a lot of research finally got tow bar. Ralliart tow bar bolts straight on One small slot to cut just under rear plate but fits perfect when you remove tow tongue you can not notice the towbar at all. Gary
Not a RA but on my VRX they had to cut the bumper, so I did this... yes its a F1 style rain light, I've got it wired to my fog lights so it is only on when they are on.
2 bolts and a wire plug and it comes off ready for the tow hitch in seconds. I think its a nice solution to a problem that really should not exist.
Users browsing this forum: No registered users and 80 guests
