Postby aspir3 » Sat Apr 02, 2016 11:40 am
Lancer1993 wrote:[img:a464a43a34]http://www.clubcj.net/cached_images/1459501789_7_PB_8162_0.jpg[/img:a464a43a34] Now I just need one of these. [img:a464a43a34]http://www.clubcj.net/cached_images/1322693953_19.jpg[/img:a464a43a34] Might be best just to go to the dealer?
I had this in my Aspire but replaced it with the coin holder as it's a lot more useful
Postby SAM-24A » Sat Apr 02, 2016 11:46 am
Postby Lancer1993 » Sat Apr 02, 2016 12:09 pm
lancerdarryl wrote:Just found them on EBay.....$10 .....just type in dual usb plug Mitsubishi and they come up. Sorry but cant do a link(computer genius !)
Yes I decided to add some USB charging ports to my CJ, only time will tell how useful they are. Still need the other bits and will see about getting it wired up in the next week or so.
Postby Lancer1993 » Wed Apr 13, 2016 8:22 pm
Some pockets... should help keep things in order when traveling, but they aren't as deep as I hoped, might need some foam under to lift them a bit.
Skrallex
Postby Skrallex » Wed Apr 13, 2016 8:43 pm
Got this in the mail today: ebay link. I'm yet to install it, waiting to see if I can get some extra dash clips before I pull it all apart again.
Skrallex
Postby Skrallex » Sun Apr 17, 2016 7:20 pm
So I installed that 12v to 2xUSB cable for my GPS, it runs through the pillar trim so you can't see what's not plugged into the gps. Since it was a 2xUSB, when I get a dash cam in the future I can use the spare socket for that.
Postby Lancer1993 » Tue Apr 19, 2016 5:05 pm
Got this for fun on eBay...
Screen is hard to read and it fell off the windscreen on a short 5 min drive to the shops.
I'll see if I can get the suction cap to stick or try it in the house on a window.
Re: "What I got in the mail today" Thread - Show 'em o
Postby Lancer1993 » Mon Jun 05, 2017 5:38 pm
Ronan.Butler11
Postby Ronan.Butler11 » Wed Jun 07, 2017 8:56 am
Finally got some decent LED parkers in, parked at hornsby westfield the other day and it looked miiiiint!
looking into getting some cooler white Halogens once my pink slip is sorted out... thinking my tires and brakes are up. Rip
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
Postby Lancer1993 » Thu Jun 22, 2017 4:36 pm
The bits are coming together!
Skrallex
Postby Skrallex » Fri Jun 23, 2017 2:34 pm
Very nice, which camera did you end up getting?
Postby Lancer1993 » Fri Jun 23, 2017 7:03 pm
This one, but while the add clearly says front view the tiny bit of instructions shows the back of a car, so over the weekend I'll rig up some 12v power and plug it into my TV to see what image I get!
http://www.ebay.com.au/itm/Universal-CM ... 2749.l2649
Postby aspir3 » Fri Jun 23, 2017 7:07 pm
I have been busy. In the last few weeks I have received kyb struts, eibach sportsline springs, dba t2 ralliart front discs and intima sr pads.
I also have new tyres but i only got cheap chinese which are fine for my daily driving
Postby Lancer1993 » Sat Jun 24, 2017 4:11 pm
Found a 12v transformer and tested the tiny camera, image is correct and not reversed, although it has built in warning lines which as far as I can see can't be removed. Some of these come with wires to cut to flip the image and remove those lines.
