so you've kinda got to log it... it's not an EBC where you dial up 23psi and magic happens in a $600 box with a circuitboard.
you'll need to do some runs, log the boost, and alter the WGDC tables accordingly to set up the 3 port properly
sleeper wrote:one or the other Al
Tweak wrote:i have a bare solenoid ( exactly same s the grimspeed) with out the pretty paint and bracked and plug. You can have it for $80 its never been used
Beeble wrote:no boost pill for a 3 port install just a line from boost source to 3 port, and 3port to wastegate actuator. 3 port will 100% block the boost signal if you want it to. so boost pill is redudant
Users browsing this forum: No registered users and 179 guests
