grimmspeed 3 port actuator
Beeble
Postby Beeble » Fri Oct 19, 2012 2:38 pm
got to set the boost buddy :)
so you've kinda got to log it... it's not an EBC where you dial up 23psi and magic happens in a $600 box with a circuitboard.
you'll need to do some runs, log the boost, and alter the WGDC tables accordingly to set up the 3 port properly
Modding or Tuning questions for your Lancer, RA or EVO? drop me a line!
http://BeebleTune.com
Postby sleeper » Fri Oct 19, 2012 2:41 pm
yep, ok, i thought thered be a standard formula, np thanks.
Glenn
Postby Glenn » Fri Oct 19, 2012 3:29 pm
We can organise a tuning/logging meet one weekend
Beeble
Postby Beeble » Fri Oct 19, 2012 3:35 pm
yeah Glenn will dial it in for you in like 10 minutes :)
Postby sleeper » Sat Oct 20, 2012 5:22 am
thanks very much glenn, shouldnt take too long should it?
i`ll order one today.
sue said ok Dan :)
squala
Postby squala » Sat Oct 20, 2012 5:29 am
Does the BCS work with the boost pill or is it one or the other?
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
Postby sleeper » Sat Oct 20, 2012 5:32 am
one or the other Al
Momengah
Postby Momengah » Sat Oct 20, 2012 8:15 am
ahh damn... that was going to be my question too. what negative effects would you imagine it would have if both the boost pill and the 3 port was installed?
-Cosworth Air Filter
-Evo X BOV
-Evo X Intercooler
-Grimmspeed 3 port
-Ultimate Racing UPICP & LICP
Beeble
Postby Beeble » Sat Oct 20, 2012 10:08 am
no boost pill for a 3 port install
just a line from boost source to 3 port, and 3port to wastegate actuator.
3 port will 100% block the boost signal if you want it to. so boost pill is redudant
Tweak
Postby Tweak » Sat Oct 20, 2012 10:16 am
i have a bare solenoid ( exactly same s the grimspeed) with out the pretty paint and bracked and plug. You can have it for $80 its never been used
Postby sleeper » Sat Oct 20, 2012 9:28 pm
sorted thanks Cam
squala
Postby squala » Sat Oct 20, 2012 10:16 pm
sleeper wrote:one or the other Al
Thanks Steve
Tweak wrote:i have a bare solenoid ( exactly same s the grimspeed) with out the pretty paint and bracked and plug. You can have it for $80 its never been used
Bugger! I already ordered a Grimmspeed.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
Momengah
Postby Momengah » Sat Oct 20, 2012 11:21 pm
Beeble wrote:no boost pill for a 3 port install just a line from boost source to 3 port, and 3port to wastegate actuator. 3 port will 100% block the boost signal if you want it to. so boost pill is redudant
So does that mean if i go 3 port I need to take out the boost pill? or replace it with the stock one?
-Evo X BOV
-Evo X Intercooler
-Grimmspeed 3 port
Postby sleeper » Sat Oct 20, 2012 11:30 pm
theres a stock one?
Momengah
Postby Momengah » Sat Oct 20, 2012 11:44 pm
yeah, theres a itty bitty one in the hose. its about half a centimetre long..
i'll see if i can take a photo of it
-Evo X BOV
-Evo X Intercooler
-Grimmspeed 3 port
Users browsing this forum: No registered users and 116 guests
