Hello,
On a quest to upgrade the look of my headlights I have decided to go with some halogen (don't want to go to LED/HID as the OEM housings are not designed for them) bulbs that are a cool white. I have found pairs for high and low beam from Mars Performance:
Low Beam: https://marsperformance.com.au/MARS-580 ... ghts-Bulbs
High Beam: https://marsperformance.com.au/MARS-580 ... ghts-Bulbs
According to this excellent post (viewtopic.php?t=224) the high beam bulb is a 60W bulb. However, the listing for the high beam bulb it says its input is 50-55W. Will these still work in the headlight?
New Halogen Bulbs
New Halogen Bulbs
Re: New Halogen Bulbs
They will be fine.I just noticed the original poster of that topic is American,they may use different spec globes to ours.The headlight globes we use are generally 55w
lancerdarryl wrote:They will be fine.I just noticed the original poster of that topic is American,they may use different spec globes to ours.The headlight globes we use are generally 55w
Thanks for clearing this up Darryl, I really appreciate it.
