TLDR;
- Has anyone tapped into the turn signals?
- By what method did you tap into the turn signals?
LONG
I've got a pair of DRLs connected to a DRL controller similar to the one below:
https://imgur.com/a/cLIotmq
I've got all the cables connected except for the yellows.
From what I've read before, although it isn't clear in any of the ebay listings for such a device, these yellow wires are triggers to turn on/off the DRLs when the car is unlocked/locked.
Based on this assumption (and also to tidy up the cables) I want to tap into the turn signals.
Correct me if I'm wrong, but unlike the headlights, the turn signals don't seem to have a fuse in the engine bay fuse block.
Therefore to tap into the turn signals, I'd have to split the wires at or near the turn lights themselves.
I've had a poke around the turn signal area and I found the wires are pretty short. Not long enough to pull out and do any major work.
My conclusion is that to tap into the turn signal, you'd have to remove the headlights to give yourself enough space to tap into it.
So my questions are:
