Better Sun Visors?
Better Sun Visors?
Postby Lancer1993 » Thu Aug 29, 2019 9:19 pm
Ok anyone else have problems with their sun visors.
Now what I'm talking about is them not staying up when forward and against the windscreen?
When I put them forward to the windscreen they drop back with maybe a 10cm gap to the glass, weirdly I had this exact same issue with my old CC coupe 1993 model but never struck it with any other car I've driven.
Now I usually have them forward as it blocks the glare from the sky or lights at night and seriously unless you're on a rally special stage who is looking up there when driving?
Any solutions?
BTW they hold fine when against the roof and fully back and up.
Re: Better Sun Visors?
Postby bumblebee » Thu Aug 29, 2019 10:46 pm
Never had that issue
One solution is to talk to a window tint place and get a piece of tint across the top of the windscreen put in. Any decent place will charge you less then $50 for it.
Or Goto a wrecker and get a new pair of visors of a wreck.
Either way I doubt it will cost much to fix
Postby Lancer1993 » Fri Aug 30, 2019 7:15 am
Thing is I don't think its just 'bad luck' I had the same exact issue with my old Lancer and its something I've not see in other makes and models. Maybe when I take the CJ in for its service I'll poke around the car yard and see what CJs I can find or others to look at?
Postby Lancer1993 » Fri Aug 30, 2019 7:19 am
Here is a short video I shot yesterday of the issue...
https://youtu.be/tTRR5K2e7Hs
Postby bumblebee » Fri Aug 30, 2019 8:14 am
I'm betting it's the hinge inside the visor
If you unclip the visor from the little clip so you can swing the visor out and then rotate the visor up and down does it do the same thing?
Postby Lancer1993 » Fri Aug 30, 2019 8:55 am
I'll be going out shortly so will try that later today.
Just seems weird I won't hold were I want it.
Postby Lancer1993 » Fri Aug 30, 2019 8:50 pm
Didn't help, maybe its just poor design.
How far forward will the visor stay up on other CJs?
Postby bumblebee » Fri Aug 30, 2019 10:49 pm
I'm positive my CY goes higher then yours
Yours goes to with windscreen and falls back to a rest then pauses and falls back even more.
That isn't right.
If you want it fixed grab a pair out of a wreck
Postby Lancer1993 » Sat Aug 31, 2019 9:57 am
Well they are 10 years old so maybe need replacing. Been a while since I've checked the local wreckers here on the Sunshine coast but last time there were none.
Postby Lancer1993 » Mon Oct 04, 2021 11:49 am
I know this thread is 2 years old but again looking at the visors.
Not replaced them but I did take the drivers one off, no real way to fix it I can see. Moving it past the point of the windscreen (when off) as it does lock into place but there doesn't seem to be a way to change this.
Also checking online the used ones aren't very cheap unless you can find one at a wrecker but it will probably have the same poor design issue I had in my last Lancer. But in other cars they seem to work, what is going on here?
adamhumphrey
Postby adamhumphrey » Mon Oct 04, 2021 4:51 pm
New from Amayama $88 plus freight.
Screen Shot 2021-10-04 at 5.49.09 pm.png (628.41 KiB) Viewed 47272 times
https://www.amayama.com/en/part/mitsubishi/7620a139ha
MY11 Evo X MR (2011-Current)
MY20 Asx GSR (2023-Current)
Mars1811
Postby Mars1811 » Tue Oct 05, 2021 10:35 pm
While on this topic, does anyone know the size of screw that holds the visor to the roof? One of the three on the driver's side is missing and I've only just remembered now.
2011 VRX Sportback
If in doubt, rev it out!
Postby lancerdarryl » Wed Oct 06, 2021 5:53 am
Take one out and have a look.At a guess probably M5 countersunk
Postby Lancer1993 » Wed Oct 06, 2021 5:33 pm
They are screws, not sure of the size. Plus they are held in with plastic 'legs' that go into the hole, I don't know why they are needed, in case the screws come out?
I'd want to get new ones if they do the same thing.
Return to “Interior”
