But I did come across a couple like this:
so which do you prefer? or would like to see? If I get web banners for front or rear windows they will most likely be solid, but this can be discussed later. I'd like to peg down the little stuff first.
sarusa wrote:Both look great, my preference leans toward outline style but other will be more noticeable.
Unfortunately for Victoria. A front windscreen item across the top, Would be illegal.
Windscreen wiper reaches to within a whisker of the top and law requires all area covered by wiper to be left clear.
Quismiff wrote:sarusa wrote:Both look great, my preference leans toward outline style but other will be more noticeable.
Does that extend to the rear window? as we don't have a rear wiper on the Lancers![]()
Lancer1993 wrote:Will they come in yellow?
sarusa wrote:Repetitive and bulky. Single line and narrower would be better. Especially i n Es and other cars with a rear spoiler
rear vision is already restrictive enough.
Lancer1993 wrote:I’d put it on the back window as long as it doesn’t interfere with the back ‘dash’ camera.
Quismiff wrote:sarusa wrote:Repetitive and bulky. Single line and narrower would be better. Especially i n Es and other cars with a rear spoiler
Do you have the VR-X spoiler on your ES? or the lower one? If I did the rear window one I would go along the bottom of the windscreen and at 75mm high it would impact on about 1/4 of the usable viewing area of the rear window, draw up a template the size Darryl mentioned and stick it to each part of your window to see.Lancer1993 wrote:I’d put it on the back window as long as it doesn’t interfere with the back ‘dash’ camera.
Depends on where the camera is located, as above along the bottom could work.
