Hardwire & Rear Dash Camera?
Re: Hardwire Dash Camera?
Postby Lancer1993 » Thu Aug 31, 2017 4:53 pm
Probably at some point, right now I've got the screen set to turn off after 1 minute...
So here are a couple of screen shoots of the low or high mount options.
I like this because the DC is out of the way from the drivers POV but not a good POV for the camea.
This is probably better, much clearer shot of the road behind!
Voting is open LOL what do we thing of the mounting options?
Re: Hardwire & Rear Dash Camera?
Postby Lancer1993 » Fri Sep 01, 2017 4:11 pm
Changed the title...
Postby bumblebee » Fri Sep 01, 2017 5:28 pm
Mount it up high above the rear wing so u have a fighting chance off seeing whats coming to rear end you. Sounds bad i know.but if it ever happens you better off with a good clear view to hand to a solicitor or lawyer
sarusa
Postby sarusa » Sat Sep 02, 2017 12:29 pm
Noted Re: turning camera on and off, If power is cut off completely. Wouldn't that throw date and time out?
Or is that handled internally, by a battery specifically for that purpose?
Skrallex
Postby Skrallex » Sat Sep 02, 2017 6:32 pm
Typically devices like these have whats called an RTC (Real-Time Clock) on-board which uses a small battery to power a crystal that keeps track of time even when the main power is off :)
Postby Lancer1993 » Sat Sep 02, 2017 8:49 pm
The rear one is my old Kaiser Baas R10+, this has a built in battery so will power it for a short time after the power is turned off. The new front is a Kaiser Baas R40 with a capacitor that gives it a little power to safely turn off when I turn the car off, but it also has GPS so no need to get the time/date.
I agree the high mount is the better option and you really don't notice it after a few minutes, I'll try and take some better photos of the position tomorrow. Best thing is with the privacy glass you can barely see it from outside. When down to the Gold Coast hinterland today, 400km round trip and it works great, only problem is people doing 40 on a nice twisty bit with a 60 limit!
Postby bumblebee » Sun Sep 03, 2017 7:48 am
Where did you find privacy glass for the lancer?
Postby Lancer1993 » Sun Sep 03, 2017 5:08 pm
Some models have privacy glass, mine is a VRX with darker back window and with rear side glass.
Postby bumblebee » Sun Sep 03, 2017 5:51 pm
Cool
Thanks
Postby Lancer1993 » Sun Sep 03, 2017 9:10 pm
I have seen a shark fine rear camera but it looks a little bulky for my liking and not sure how it would record what it sees, maybe its just for parking? But it is an ideal location for a camera to catch everything.
Only interesting thing I saw with the rear one was someone carrying a mattress on the roof over there SUV with one rope, so the front as bent up like a banana :lol: shame they turned off before a 80kph section of road :(
Postby bumblebee » Mon Sep 04, 2017 6:16 am
Did they have roof racks on the car ir did they wind the windows down a bit and tie it to the roof and feed the rope thru the windows then climb into the car like the duke boys did with the general lee?
jjb
Postby jjb » Mon Sep 04, 2017 7:46 am
Yeah, I would vote the higher placement for camera :D (not sure if voting is still open) as that way you should clearly get number plate details, etc. in the event of running into an idiot (or more so, an idiot running into you :shock: )
Side note: I forgot that you're Sunny Coast, and was thinking, wow the highway in Vic looks so much like Queensland's highway :lol:
sarusa
Postby sarusa » Mon Sep 04, 2017 9:50 am
bumblebee wrote:Where did you find privacy glass for the lancer?
You can buy the film to DIY from Autobahn. If your game enough to install it yourself.
Better alternative, there are a number of places that will install it. Had mine done, a year ago,
Four side windows and rear window. Very pleased with the results. I think it was for $260
Work carried out at my home, by Southern Cross Tinting. Andrew 0438 675 808 :D
Postby Lancer1993 » Mon Sep 04, 2017 4:29 pm
bumblebee wrote:Did they have roof racks on the car ir did they wind the windows down a bit and tie it to the roof and feed the rope thru the windows then climb into the car like the duke boys did with the general lee?
I'll have to check the video but I didn't see a roof rack or ski rails in my mirrors. Either way it wasn't tied on well and should have had a 2nd rope on the front.
Return to “Electrical”
Users browsing this forum: Majestic-12 [Bot] and 12 guests
