Interior trim clips
Lancer1993 wrote:Yeah but $70 postage? Ill give mine a complete check, maybe the missing one is hiding some place.
Did you check your dealer with the part number? I know $3.35 is steep for what it is, but yeah compared to ebay... I can send you my remainders if you can't get them from your dealer.
EDIT: I think I've got 2 remaining. When I pulled off the fake-carbon-fibre-ish dash trim piece, there were 3 clips missing from the underside of that. Maybe somewhere in the dash, but I looked and couldn't see any, I assumed they'd have rattled around and ended up somewhere else.
- bunnishiwa
Guys, go to a wreckers where you can pull off your own parts. I got 10 off a lancer at Jolly's in Dandy and they didn't even charge me for them
- Lowered on Kings
- Whiteline Rear Swaybar
Noli Timere Messorem
- Lowered on Kings
Re: Interior trim clips
If you search ebay on mitsubishi clip
You will find some.i found some that are black in colour and have some on order.i bought 20 of them incl. Freight for $4.30 AUD
Thanks I got some when I got a replacement air vent.
bumblebee wrote:If you search ebay on mitsubishi clip
Got a link? Just had another quick look and couldn't find any of the right type, they were all the other two-piece type.
Are these the ones you want?
Ebay item
381409438484
I have bought another packet to keep for spares
Ebay item
381409438484
Save info to save for prospety
- Attachments
- Screenshot_2017-06-28-21-25-20.png (281.58 KiB) Viewed 15290 times
More info to save to nake it easier for someone to buy them down the track inexpensively
Description:
These rivet fasteners are made of plastic material, suitable for car use.
These clips are used by many manufacturers to hold all pieces of trim and upholstery including carpet, door cards, roof lining, engine covers, landing panels, boot linings, wheel arch linings etc.
Total Length 18mm/0.7"
Quantity (±2%)50
Other Part Number a15111300ux0173
Material Plastic
Head Diameter(max.) 0
Interchange Part Number a15111300ux0173
Color White
Product Name Clips/Rivets/Fastener
Manufacturer Part Number a15111300ux0173
Applications2 NYLON CHRISTMAS TREE Carpet Floor Mat Clips
Package Content 50 Pcs(+/-2%) x Rivet Clips
Applications1 Defender Door Card Interior Weatherstrip Moulding
Fit Hole Size 6mm/0.24"
Stem Length 0
Description:
Quantity (±2%)50
Material Plastic
Color White
Stem Length 0
Huh, they are too. Nice, I couldn't find them anywhere searching with "Mitsubishi Clip" or anything like that. I'll definitely order some of these. Hopefully they are a little stronger and less prone to breaking than the default ones. If so, I might replace a whole bunch, as the shitty white ones break frequently.
