Carbon Fibre steering wheel skin
Re: Carbon Fibre steering wheel skin
They look pretty flash......are you able to put up a link for anyone who is interested?
Sorry thought i added the link in the original post.
http://www.ebay.com.au/itm/262604019480 ... EBIDX%3AIT
Can't go too wrong for $6
- Mystique
Looks good (y)
Not bad for the money.
How did you clean the surface before applying them?
Just gave it a quick scrub with isopropyl to clean it off.
Its got a pretty decent stick to it though.
just ordered some for mine, will actually match the interior trim of my car!
Nice find!
Nice find!
Black 2010 VRX Lancer
- Ronan.Butler11
Love the look of it, is it subtle with the rest of trims in the car?
Looks sick man, cheap as well!
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
Yeah it matches the interior really well, especially cause mine has the glossy black trim interior.
I also ordered these: http://www.ebay.com.au/itm/271171043647 ... EBIDX%3AIT
Which are bit pricy for what they are but also look really good and pull the look together.
I was wondering how hard is it to take the wheel apart if I wanted to paint that bit?
Not a clue sorry, think it would be a bit of a hassle.
Maybe if you don't like the carbon fibre look you could use some plain black vinyl.
I don't mind the CF, did the bit behind the number plate and have home made bits around my interior door handles.
Would be nice if someone made some downloadable PDF of the cutouts to do this at home, including the ones around the side vents and other parts of the interior!
- Ronan.Butler11
from reading online on the back of the silver area with the buttons are 2 screws, one each side. undo them, pop it off. apparently you have to individually remove the buttons from the silver housing though.
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
Didn't think vinyl wrap would grip well on rough internal plastic surfaces!
I put some on the front doors around the latches and its stuck well, but need to redo them as I was never happy with the way I cut them to fit.
