Hi guys, two days ago, I noticed my CJ Lancer ES 07's cruise control suddenly stopped working, then today the "service required ASC OFF" light came on as per image during driving (possibly from braking)
P/S the cruise light will come on when I press the button, but I can't set the speed nor increase speed
But there's more, today after work, I tried to drive my car, my shift was stucked at "park"! I had to pry open the hole to release the shift to drive! What's going on here?! Why suddenly so many issues happen at one time? I presume they're all related?
Hope this is not an expensive exercise
Cruise ctrl not working, stucked at P..what happen?!
Re: Cruise ctrl not working, stucked at P..what happen?!
Check if your brake lights are working. If the brake switch is stuffed it won't release the park lock or engage cruise control.
Have you got any mods like led lights? Those aftermarket tail lights cause these issues without resistors fitted
aspir3 wrote:Have you got any mods like led lights? Those aftermarket tail lights cause these issues without resistors fitted
nope, all standard ..
It's pretty much confirmed it's brake light switch malfunctioned after talking to a few mechanics, but they all wanna charge me $90-100 to get it replaced..geez!
Is it pretty easy to do? since they say will only take them 20 mins. Could someone please guide me how to fix it myself?
Where is that located, in the cab?
Lancer1993 wrote:Where is that located, in the cab?
Its mounted on a bracket on top of the brake pedal
it wont be visually broken, the contacts inside have just worn to the point that they no longer touch properly or a build up of dust is stopping contact.
if you think you can open it without losing anything and being able to put it back together you could clean it out and see if it works after that. or soak it in metho/brake cleaner/ electrical contact cleaner and shake it around and air blow it may fix it too.
or just buy a new one from mitsubishi/wreckers.
