Steering Wheel Switch
Hey guys I own a ES Lancer and it doesn't have a control for the audio (volume up + down, next track etc) built into the steering wheel. I was looking to buy one from a wreckers, I already have this lined up. Either from a higher level lancer, a ralliart or a evo. I also have an aftermarket head unit. I was wondering whether there would be a way to transfer a wheel across, and whether it would be easy?
Re: Steering Wheel Switch
One thing to keep in mind is the airbag, if you get the same wheel design you can use the one you have.
If you get one from an EVO or RA they a different design and most from the wreckers won't come with the airbag.
Not sure if your CJ will come with the wiring, thats a question for someone else to answer.
How much is the wrecker askin for the volume controls for the steering wheel?
Merlinised
U can have it for steering control and the loom for 40 as almost brand new
@EvoXra from where dude? and what comes with the loom?
Whole car wrecking atm let me know I'll part it out from brisbane
