Door Latch Cover
Door Latch Cover
Postby Lancer1993 » Wed Jul 27, 2016 7:07 pm
So decided to get covers for the door latch, just a tiny 'mod' to dress them up but they don't fit. I've notified the seller (assume I chose the right ones) but not worth sending back as it's only a few dollars.
Below is the eBay listing, anyone else tried them?
http://www.ebay.com.au/itm/231425470354 ... EBIDX%3AIT
CJsportback
Re: Door Latch Cover
Postby CJsportback » Wed Jul 27, 2016 7:22 pm
It's a shame they don't fit, very simple little change but actually looks really nice.
Postby Lancer1993 » Wed Jul 27, 2016 7:47 pm
I'll let you know if the seller responds.
Postby lancerdarryl » Thu Jul 28, 2016 12:11 pm
The ones I have are from a different seller (Chinese) and are the same.
Postby Lancer1993 » Thu Jul 28, 2016 4:22 pm
I was told to warm them up, with some hot water or a heat gun, not sure if this will help?
Viking
Postby Viking » Sat Jul 30, 2016 5:22 pm
Heating them with hot water (depending on the thickness of the plastic, the water might need to be almost boiling) and then stretching them should do the trick. A heat gun might be too hot if you're not careful.
Postby Lancer1993 » Sat Jul 30, 2016 7:39 pm
Not confident either will work, needs to be a couple of mm wider if you look at the photo I took. Wish they were rubber and could be stretched.
BTW I didn't get a chance to try it today, hopefully tomorrow.
Return to “Interior”
