Hello Guys, Have a rattle in my dashboard
mido45
Postby mido45 » Thu Jul 14, 2016 6:36 am
Hello Guys,
Happy to be here.
I was wondering if someone had the same issue , I newly bought Lancer but I am hearing annoying rattle sound in the dashboard like a vibrating sound because of something loose, I don't know exactly. but If someone had the same issue or had removed this rattle please share your experience.
Thanks in advance and Happy to be here.
Cheers,
Dannn
Re: Hello Guys, Have a rattle in my dashboard
Postby Dannn » Thu Jul 14, 2016 9:08 am
It could be that someone before you has taken the dash apart and broken a few clips?
Merlinised
Kyrus
Postby Kyrus » Thu Jul 14, 2016 9:37 am
I have the same, keep trying to find it with no luck.....
燒
sarusa
Postby sarusa » Thu Jul 14, 2016 1:07 pm
Haha something is loose!!!!!!
CityCruiser
Postby CityCruiser » Thu Jul 14, 2016 1:42 pm
mine had rattle sound, but came from engine bay and only during certain RPMs.
Not that it's the same, but maybe you'll find something viewtopic.php?f=78&t=18836
2012 Lancer ES CJ MY13
Automatic
81,000KM
mido45
Postby mido45 » Thu Jul 14, 2016 10:26 pm
Thanks guys for your feedback , The car is new btw . At least now I know I am not alone.
Postby Lancer1993 » Fri Jul 15, 2016 7:43 am
I should have asked what kind of rattle and is it only at certain speeds or RPMs?
I had half my dash apart recently to fit a new instrument cluster and as far as I can tell there are no rattles so far.
With a front seat passenger go for a drive and try pressing on parts when you hear it, might narrow down what is making the noise.
sarusa
Postby sarusa » Fri Jul 15, 2016 10:24 am
mido45 wrote:Hello Guys,
Happy to be here.
Thanks in advance and Happy to be here.Cheers,
Only moving part in dash is air conditioner - heater. Try turning these systems completely off at the middle controller and switch to
re-circulation to stop all air flow, then listen!. Secondly under the dash behind the glove box, looking at it from the passenger sea,
there's a plastic panel under the air con: unit that is loose and if tapped with your hand will rattle!!? Hold steady with your hand or preferably a passengers hand for safety sake, when in motion. Hope these help.
CityCruiser
Postby CityCruiser » Fri Jul 15, 2016 12:27 pm
Happy to be here.
Needless to say, do this in a super safe condition or like sarusa suggested with a passenger.
Don't want to scratch / put a dent on that shiny car :wink:
Automatic
81,000KM
Falcoon
Postby Falcoon » Sat Aug 13, 2016 9:50 am
Guys,
I've a 20111 manual CJ sedan and have what I would describe as a resonant buzzing at revs between 2000 and 2500 rpm. It appears to be independent of gear. Suspect causes have been the heat shields in the engine bay (over the manifold and against the firewall) and the dash, but to date I have not traced the cause.
It may be of use to some to note that the plastic garnish around the passenger light and hazard switch was missing two white nylon clips from new. The attached photos shows the garnish and one of the mounting posts, with an irregular slot highlighted by a paper background. Two posts had no such slots and I had to drill them out to fit the missing clips. In my case at least, the buzzing is still apparent with the garnish removed.
I welcome anyone who can identify the source of the buzzing.
Dashboard garnish.jpg (465.65 KiB) Viewed 18219 times
Dashboard garnish clip.jpg (307.85 KiB) Viewed 18219 times
Skrallex
Postby Skrallex » Sat Aug 13, 2016 11:37 am
Yeah my VRX was missing those when I pulled it apart for the first time too (though I am second owner). Did you manage to get some clips? I had to contact mitsubishi, I have the part number if you wanted to get some.
Falcoon
Postby Falcoon » Sat Aug 13, 2016 1:06 pm
Yes thanks. Mitsubishi supplied them free of charge as the car is still under warranty. I should have, but did not get the part number, so it would be worth listing for reference if you have it.
BTW, on the posts whereyour clips were missing, were the slots missing?
Skrallex
Postby Skrallex » Sat Aug 13, 2016 4:42 pm
Slots didn't seem to be missing for me. See this thread for item part number.
