tow bar for lancer CJ or Ralliart
black_ice
Postby black_ice » Tue Feb 18, 2014 2:51 pm
Until Andrew mentioned it I did not think they would have different part number..for eg if you needed a new TCU i can understand why the part numbers would be different but for other mechanical stuff (clutch packs) shouldnt it be the same?
R4LLI4RT
Postby R4LLI4RT » Tue Feb 18, 2014 3:03 pm
i would say so.
i always thought just the software would be different
hence why you can make a ra have s-sport
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
zedd82
Postby zedd82 » Tue Feb 18, 2014 4:41 pm
Well Mitsubishi don't sell just the gears etc. to go in them, they only sell them as a whole unit except the clutches, so they would have to be different part numbers if you think about it to distinguish between the RA and Evo boxes.
Pretty simple really.
gman90
Postby gman90 » Tue Feb 18, 2014 5:46 pm
Well I am confused they must be the same box surely and different software ????????
R4LLI4RT
Postby R4LLI4RT » Tue Feb 18, 2014 6:03 pm
what are the part numbers id like to compare?
DBA Extreme Pads
Tein S Tech Springs
Re:
Postby Lancer1993 » Wed May 27, 2020 3:29 pm
gman90 wrote:After a lot of research finally got tow bar. Ralliart tow bar bolts straight on One small slot to cut just under rear plate but fits perfect when you remove tow tongue you can not notice the towbar at all. Gary
Not a RA but on my VRX they had to cut the bumper, so I did this... yes its a F1 style rain light, I've got it wired to my fog lights so it is only on when they are on.
2 bolts and a wire plug and it comes off ready for the tow hitch in seconds. I think its a nice solution to a problem that really should not exist.
Users browsing this forum: Bing [Bot] and 13 guests
