Dirtee
Postby Dirtee » Tue Jul 03, 2012 10:30 am
hahha glenn... i better make sure the r34's are tight then :P
2010 Lancer Es - My Ride
Wanna be customiser!!
ACT Rep 2012
CJLancerInstalls - How-To's!
Postby bd-850 » Tue Jul 03, 2012 10:38 am
Dirtee wrote:hahha glenn... i better make sure the r34s are tight then :P
you wouldnt have enough boost to blow it off :P
Dirtee
Postby Dirtee » Tue Jul 03, 2012 10:41 am
bd-850 wrote:[quote:c9e085c5d2=Dirtee]hahha glenn... i better make sure the r34s are tight then :P[/quote:c9e085c5d2] you wouldnt have enough boost to blow it off :P
Ben, you have enough boost in your head to blow it off :P
ACT Rep 2012
Glenn
Postby Glenn » Tue Jul 03, 2012 11:15 am
haha i was surprised how little boost it took. It popped off on the UCIP side of the turbo inlet which uses a reducer that doesn't have much extra silicon so she's gotta be hella tight.
t clamps on their way!
Postby lancerdarryl » Tue Jul 03, 2012 12:17 pm
glenn spray the insides of your silicone connectors with hairspray then assemble them before it dries.They will never blow off again.No problems with sticking if you are pulling them off at a later date :)
Dazz4C
Postby Dazz4C » Tue Jul 03, 2012 12:57 pm
Zaki wrote:got these pretty cheap to replace the stock front speakers and come with tweeters for $52.00 from superdoopa cheap [img:590f544a58]http://www.clubcj.net/img/images/20120703005939_fusion.jpg[/img:590f544a58]
Don't the tweeters need a new cover to mount properly?
Zaki
Postby Zaki » Tue Jul 03, 2012 3:49 pm
im not sure yet till i rip off the cover :s
Dazz4C
Postby Dazz4C » Tue Jul 03, 2012 3:55 pm
Swapped out the crappy yellow/amber bulbs on the LED tails for some proper chrome amber ones...
Ended up cracking the corners off both sides of the tail lights. FML.
BR14AN
Postby BR14AN » Tue Jul 03, 2012 7:35 pm
Refurbished my new wheels
Rays volk 17x8 +35[/img]
BR14AN
Postby BR14AN » Tue Jul 03, 2012 10:37 pm
bez3rk wrote:if they are going on your lancer they are gonna look reall good white n green. :D
yeah they will be, ill post up a picture or two once theyre on :)
longa
Postby longa » Tue Jul 03, 2012 11:09 pm
Nice wheels Brian !! how much did those set you back?
BR14AN
Postby BR14AN » Wed Jul 04, 2012 8:30 am
$600 :D and I pulled them apart, polished and resprayed them myself, so all up including supplies around $750
Postby JustinR » Wed Jul 04, 2012 9:13 am
Your Lancer is going to get some phat stance isnt it ;)
debonaire
Postby debonaire » Wed Jul 04, 2012 10:29 am
Glenn wrote:haha i was surprised how little boost it took. It popped off on the UCIP side of the turbo inlet which uses a reducer that doesnt have much extra silicon so shes gotta be hella tight. t clamps on their way!
Ha, I did this in my Skyline once, on a busy road in Toowong.
I had half-arsed some pipes back together because I was in the middle of some work, and thought I'd just drive around very carefully for a couple of days rather than tighten all the clamps that were super hard to get to...
It worked well until a car pulled out in front of me unexpectedly and I had to lift off the gas quickly. As soon as the throttle body snapped closed, the pressure found the path of least resistance and there was a Whhuzzzz! from the front of the car. Luckily I was in the left lane and there was somewhere to pull over, just happened to be outside a Kmart Tyre & Auto so I borrowed a trolley jack and manhandled it back together in the gutter. :oops:
Users browsing this forum: No registered users and 69 guests
