Postby Lancer1993 » Sat Nov 14, 2015 2:44 pm
bongo
Postby bongo » Sat Nov 14, 2015 8:10 pm
Lancer1993 wrote:[img:f4b856e5e0]http://www.clubcj.net/cached_images/1447476297_7_PB_8162_0.jpg[/img:f4b856e5e0]
Hi I assume you removed the sway bar before you painted it. Is it just a matter of removing the 6 nuts?
Thanks
Postby Lancer1993 » Sun Nov 15, 2015 5:05 pm
Yep, parked in the garage, flat and level. Put the nuts back on loose but didn't move the car but if you need to just do the nuts up to the right torque settings and unless you go crazy through corners you probably won't notice it's off.
luke_1993
Postby luke_1993 » Wed Nov 25, 2015 2:08 pm
NEW TAIL LIGHTS WOOOOOOO :D
I'll take some night shots later i couldn't wait any longer to put the photos up and show everyone.
Haza92
Postby Haza92 » Wed Nov 25, 2015 4:16 pm
Just installed a strut brace and RA snorkel :)
Haza92
Dire
Postby Dire » Sun Nov 29, 2015 3:53 pm
Replaced my front sway bar, still need to do my back one and its end-links. Back one is harder as you have to drop the exhaust and take off a chassis brace.
Has ruined my handling for now of course because I've only done the one, oversteer city :P
Re: What did you do on your car today?
Postby Lancer1993 » Sat Dec 09, 2017 2:43 pm
A year since this thread was used, thats no good so time for a pointless decal LOL!
rasit.aslim
Postby rasit.aslim » Sat Dec 01, 2018 2:59 pm
New sub and amp! Still waiting on speakers tho haha
2017 Lancer ES CF Sport
rasit.aslim
Postby rasit.aslim » Mon Dec 03, 2018 12:29 pm
Stebel Nautilus horn fitted, this thing is seriously LOUD.
The horn location looks factory imo, hard for someone to notice where its fitted haha.
Kicker sub and amp also fitted, sub is small but packs serious power. Would recommend if you're tight on boot space. I also relocated the fire extinguisher location, boot is less cluttered now.
Rocket8
Postby Rocket8 » Fri Dec 07, 2018 8:29 am
Passed the service for 30,000 miles on my Tata Nexon, replaced the oil, and looking for a subwoofer, at least 1.5 kW. Any advice?
FlyingWombat
Postby FlyingWombat » Sat Dec 08, 2018 12:28 pm
First service on the Galant today: fluids were all changed right before I bought it, so today was just a general look-over and seeing what needs to be done.
The tyres are roadworthy, just, so they're going to need to be replaced pretty soon, but I'll wait around til after Christmas and see what specials come up.
The wheel nuts, all of them, were massively overtightened, easily around the 150Nm range, if not more, and I needed to use my 1.5m breaker bar (that I normally only need for axle nuts or suspension bolts) to get the wheel nuts loose!
Changed the rear brake pads - hadn't been changed in a very long time, and when I went to remove the right-rear caliper, I found out why... the lower guide pin bolt head had been rounded off, and none of my sockets or spanners could get a grip on it. The other bolts were also massively overtightened already, and needed a good long breaker bar to loosen. Eventually, my partner managed to fit an impact socket on by hammering it down, and she was able to loosen it off, though the bolt head was pretty much destroyed.
All good, found a replacement pin from a Lancer at the local wreckers, and the new brake pads are in and ready to go.
Oh, and I torqued the wheel nuts properly.
Postby Lancer1993 » Sat Dec 08, 2018 2:04 pm
From memory wheel nuts are meant to be around 90Nm, maybe 95? I keep a torque bar in my boot if I need it. Oh and a lot of the time I now carry my torque wrench :)
Quismiff
Postby Quismiff » Sat Dec 08, 2018 7:37 pm
Lancer1993 wrote:From memory wheel nuts are meant to be around 90Nm, maybe 95? I keep a torque bar in my boot if I need it. Oh and a lot of the time I now carry my torque wrench :)
Except when you take the car to a tyre shop of rip shit and bust merchants who use a 3/4 drive impact wrench to do all the wheel nuts up
2007 MY08 VR-X (cj-red)
Users browsing this forum: No registered users and 78 guests
