USB interface socket
Has anyone purchased / installed one of these USB interface socket systems into the blank buttons on their dash?
If so would it ge easy for an electrician noob to do? Or would it be just better to get one of those dual 12v ubs plugs?
Appreciate your info. Thanks
- Attachments
- image.png (331.4 KiB) Viewed 16685 times
Re: USB interface socket
They look good. You just need to find a power and earth. Cigar lighter is alway a god place.
- FlyingWombat
I just installed a very similar one in behind my glovebox to power my dashcam. Super easy to install, and yeah, I agree, get the power from behind the cigarette lighter.
I got one similar 3 years ago and it works, but I have noticed only one of the USB ports (on mine) seems to have enough power for my iPhone. But it does work and is a great options to power up or charge a phone without having to plug something in the 12v socket.
Lancer1993 wrote:I got one similar 3 years ago and it works, but I have noticed only one of the USB ports (on mine) seems to have enough power for my iPhone. But it does work and is a great options to power up or charge a phone without having to plug something in the 12v socket.
Quick question where do you get that cover button thingy to replace the stock coin holder??? Are those off the Evo's?
wouldn't mind having a usb charger but would prefer it to be there instead of over at the drivers side door...
Black 2010 VRX Lancer
- Ronan.Butler11
fairly sure they are off the RA or Evo.
stuff like this is pretty easy to install once you take a second and look at how you are going to do it. dont rush, i did that with a boost gauge on the project and it looks like arse
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
Ronan.Butler11 wrote:fairly sure they are off the RA or Evo.
Yeah just found them online just didnt know what they were called, but you are right they are off the RA/EVO. Found the part numbers and the dummy buttons as well to fill in the rest of the holes.
Yeah sounds like a plan. Cheers for the info.
Got mine at the dealer...
You can also get a switch blank if you need them.
- lancer2014
RRM crank pulley
RA snorkel
Takeda intake
Ecu reflash
Magnaflow cat back 2.5
Tein Flex Z Coilovers
Avid 1- 06 18 x 8.5 x 35et
Hidro Real Carbon
RA snorkel
Takeda intake
Ecu reflash
Hidro Real Carbon
BTW I checked the USB ports on mine with a volt amp tester I got on eBay and found yes only of my ports is not working
Doesn't really matter as I usually only have one device plugged into it at a time. I'll need to check the wiring to see if I can unplug it, can't remember how its wired in.
Usually they are 3.1A for the 2 ports - 1 2.1A and 1 1.0A. (There are newer one with Quick Charge 3.0 with up to 2.4A dual ports).
Looks like the 2.1A port is not working and you got only the 1.0A.
For sure will take a long time to charge up anything with 1.0A.
Okay ripped out the panel and checked the wiring. should be able to just unplug mine to swap it for a new one.
Checked on eBay and I noticed some have volt meters (for the car) built in but I can't find one that fits this style of switch hole for the Mitsubishi.
Just ordered this one on Aliexpress, less than $20.
Will take a few weeks to get here and will see how it goes then.
https://www.aliexpress.com/item/Origina ... 4c4dleNHuE
Can't wait for my new one, should just plug right in.
Just choose the right lead, you need something low profile with flex, especially if you drive a manual, don't need the USB lead getting in the way of a gear change. Still a great solution when traveling and someone needs to charge their phone. Oh also make sure the lead is long enough, just in case they want to take photos while driving, not the driver.
Users browsing this forum: No registered users and 50 guests
