What are these wires?
Postby Lancer1993 » Sat Jan 23, 2016 8:05 pm
Looking around to install a garage switch in my CJ
And found these wires attached to the bottom of the coin holder, are they just part of the MY09 wiring harness or do they actually do something like the ASC switch?
Also noticed that a tiny white clip is missing, it helps hold the panel with the cup holders in place. Are they hard to get?
I'm tossing up weather to get a ASC switch and other parts to replace the coin tray or do something else for a garage switch.
Postby aspir3 » Sat Jan 23, 2016 8:23 pm
They are for other features that your car does not have. I believe they are for active headlights (hid) and AWD system for ralliart and evo.
Postby Lancer1993 » Sat Jan 23, 2016 8:53 pm
Thanks, so I can't just plug them in and get a Ralliart Lancer? LOL
So if I put in a ASC switch to open/close the garage I can just drop the wires and forget about them?
I guess I can get a clip from the Mitsy dealer?
Postby aspir3 » Sat Jan 23, 2016 9:00 pm
Yes the wires will be fine just loose. Any switch that fits will do. I personally would fit it on the dash next to the asc button
Just a tip, most Mitsubishi switches will fit. Most get them from Magnas as there are plenty around and cheaper
Postby sleeper » Sat Jan 23, 2016 11:14 pm
lol craig, u wish :)
now wheres the wires for the evo yaw control, heh.
Postby Lancer1993 » Sun Jan 24, 2016 7:43 am
I asked at a wreckers but they didn't have any, unfortunately Friday I got caught up doing something else so didn't have time for a large search. I will be heading to Redcliffe next week so might spend the day down in Brisbane and visit a few wreckers down there.
I knew there used them in the 380, wasn't sure about the last Magna's, good to know. I guess they used them in a lot of Mitsy built around the same time.
How hard is it to move a switch on the same panel, if I do put it in the dash one I'd like to move the real ASC over one slot. Was also considering painting the garage one so it's really a stealth install.
Postby Lancer1993 » Sun Jan 31, 2016 8:51 am
Found another false switch in the panel on the dash net to the ASC switch, guess it's the same, wires used on a different model CJ.
Postby aspir3 » Sun Jan 31, 2016 9:25 am
There may also be some under the passengers seat and boot for amp and sub
maciman992
Re: What are these wires?
Postby maciman992 » Sun Sep 11, 2016 6:00 pm
Can we use these wires for something like a power supply feature?
SEB15
Postby SEB15 » Sun Sep 11, 2016 8:25 pm
Might work if you have the fuse in the fuse box and then work out wich one is the positive, but also you might end up with errors from ECU thinking the AWC is alive but not working, so you might end up with a "AWC service required" on the dash
sarusa
Postby sarusa » Mon Sep 12, 2016 9:51 am
[quote="Lancer1993"]Looking around to install a garage switch in my CJ
I believe those switches are for heated front seats in up market models. As yours is a VRX, must have only come into use in later models..To check, find spare wires under front seat and see if you can trace it back to those wires with a meter. If right then you know which fuse its connected to. :D
Postby aspir3 » Mon Sep 12, 2016 12:43 pm
They are not for seat heaters. They are for awd and active headlight switches
sarusa
Postby sarusa » Mon Sep 12, 2016 12:58 pm
aspir3 wrote:They are not for seat heaters. They are for awd and active headlight switches
Stand corrected seat heater switches are behind drink holders.
sarusa
Postby sarusa » Mon Sep 12, 2016 1:41 pm
Marked left blank, center "SONAR" right, "AWC" in MY12 to MY15 Ralliart and possibly others. :)
adamhumphrey
Postby adamhumphrey » Fri Sep 16, 2016 6:03 pm
Here is what the switches are in my my11 Evo X MR
The middle one on the Evo is the water intercooler spray but isn't used on the MR. I fitted a TPMS in there instead.
MY11 Evo X MR (2011-Current)
MY20 Asx GSR (2023-Current)
Return to “Electrical”
