Hey! bonnet gapping
CJTas
Hey! bonnet gapping
Postby CJTas » Sun Oct 30, 2011 12:09 pm
Hey i had bought a carbon fiber bonnet n had it installed, when i found out it was illegal i sold it, when i reinstalled my old bonnet the gap is uneven in certain parts, is there a trick to this is there special nuts for it that lines it up nice, cos i dont have the original nuts from the bonnet, any ideas?
thanks in advance :)
driftnut((
Postby driftnut(( » Sun Oct 30, 2011 12:53 pm
pics would help and so would putting it in the right thread
CJTas
Postby CJTas » Sun Dec 11, 2011 10:52 pm
yeaaaaa where dat??
Is the bonnet not part of the exterior????
RAwannabe
Postby RAwannabe » Sun Dec 11, 2011 11:08 pm
In my old car I had the same problem, I took it to the local smash repairer, they told me whenever they took the bonnet off, they mark the nuts before hand, maybe you need to loose the nuts and align them.
CJTas
Postby CJTas » Tue Dec 13, 2011 1:30 pm
Thank you i will def look into that, also might go down to mitsubishi and order the original nuts in, might be better then th nilock ones im useing now somehow lol
13EZY
Postby 13EZY » Tue Dec 13, 2011 7:36 pm
the nuts will cost you around 75 cents each from Mitsubishi. But before you pass on that enormous sum to MMA try undoing your existing ones. If there is a bit of play in your bonnet, try a slightly different position. Bit of trial and error should get it straight
Ride Of The Month June 2011
Postby aspir3 » Tue Dec 13, 2011 7:47 pm
Where are the gaps?
Your guards may need to be adjusted as well.
Users browsing this forum: No registered users and 89 guests
