Vpower for RON91 price this sunday
dumb&
Postby dumb& » Thu Mar 26, 2009 7:37 pm
http://www.colesexpress.com.au/vpower/
Fill up with Vpower at the price of regular unleaded this sunday :)
Mizta B
Postby Mizta B » Thu Mar 26, 2009 7:46 pm
Thanks Daveee
Just printed the voucher for Sunday
Good on you mate
Merlinised....
3mPty
Postby 3mPty » Thu Mar 26, 2009 9:06 pm
YYYAAAHHHOOOO!!!!!!...NICE INFO....
Smokin'.....
777_AJB
Postby 777_AJB » Thu Mar 26, 2009 9:34 pm
wats so good about v power then i would liek to no whats the difrence apart from it costs more ?
leevin
Postby leevin » Thu Mar 26, 2009 11:02 pm
ooo good coupon! too bad i use bp premium but thanks anyway!
07 CJ VRX BLACK LANCER
Dummer
Postby Dummer » Thu Mar 26, 2009 11:14 pm
777_AJB wrote:wats so good about v power then i would like to no whats the difference apart from it costs more ?
its a higher octane fuel so it contains more energy per litre. In car's with knock sensors the ECU can advance the timing and get better performance from the higher octane fuel. they are also supposed to be more refined and have better quality additives that keep your engine running cleaner.
But the main benefit of a high octane fuel is they have a higher flashpoint (temperature at which they self ignite) and that means high performance engines can run higher compression ratios which increases engine efficiency.
ash06
Postby ash06 » Fri Mar 27, 2009 12:03 am
Cheers for the voucher daveee!
&Good info Ryan_C!
mitsfan
Postby mitsfan » Thu May 07, 2009 10:24 pm
[V-Power] its a higher octane fuel so it contains more energy per litre. In car's with knock sensors the ECU can advance the timing and get better performance from the higher octane fuel. they are also supposed to be more refined and have better quality additives that keep your engine running cleaner.
Can anyone confirm if the Lancer CJ VRX 2.4l does include knock sensors?
Thanks.
Ravine
Postby Ravine » Thu May 07, 2009 10:32 pm
Thanks.
All of our cars are capable of running V-Power. The ECU will automatically adjust to the new higher octane fuel and give it better performance.
mitsfan
Postby mitsfan » Fri May 08, 2009 9:20 am
Thanks Ravine,
Do you have any details on how the non-turbo Lancers adjust to 98RON fuel? (e.g. if they include any knock sensors, or if not how they use other types of sensors to adjust to different fuel?)
As an aside, does the Lancer ECU adjust for changes in air inlet characteristis when you change air filter, for example, and if so over what length of time does it do this (i.e. what's the integration period)? :?:
dumb&
Postby dumb& » Fri May 08, 2009 9:21 am
It could take a few days, it could take a week.
Generally a few days. :)
