The alarm has locked me out
Bruce
I've had a Lancer Ralliart Hatch for about 6 months only mod is new wheels 18x8 to fit 235/40/18. Here's the problem jacked it up at the front to check one of the front tyres, alarm (factory) went off, tilt sensor . Pressed key remote lock doors to turn off alarm. Then unlocked got in car put trans in neutral, steering lock off, key in middle position. Continued to check front wheel. Dropped car off jack, wont open on remote? wont open on keys, no response other than when pressing lock button on door or hatch about 10 seconds of beeping then nothing. Mitsubishi & NSW - NRMA have no idea. Stuck in my garage what a beauty, any ideas? Will Try and put this post in electrical as well. Darrell
The factory alarm should have an override (2 i think, one mechanical and one electrical)
you should of been given a PIN with your alarm system, if you put your key in the ignition to the ACC switch and leave it for X seconds that counts as a digit.. rinse and repeat for your alarm combination
or you can use your circle key thingo to override the alarm which is in the engine bay..
atleast that's how it worked on my old lancer with the factory alarm
Hope that helps
Hope that helps
Daily Driver: Yamaha R1
- shamrockshirts
Bruce
I tried putting the temp key backward into the fob but still NFG. Mitsubishi just send the NRMA guy who doesn't know how to get into it, he wants to wedge the top part of the door open then put a small airbag in and inflate that till he has room to use a rod to try and turn the interior door lock at the front manually. My issue is he's says it may permanently bend the door and it may not work because if the key isn't mechanically connected to the locks (It wont overide the electronic door lock) the front internal lock may only being electrically connected. Its looks like getting down to whats cheaper to replace a door or a window. Even towing it out of my garage is going to present some real problems. Darrell
