I have been looking at the Calibre 5 inch 4 in 1 tacho from super cheap and was wondering if anyone has installed one of these into there Lancer and if so how did they go.
Also is the gauge any good or is it a waste of money.
thanks in advance
New Member *gordo37*
- gordo37
bd-850 wrote:i think its a waste, as you already have a Tacho and Temp gauge in the car so why need more
yeah well i would like to be able to see my trip meter and be bale to see my temp as well, and also i like the idea of the temp in C and not F, plus also it has volts and oil pressure all in the one unit, i like the idea of it
or am i a tool for thinking it is a good idea
gordo37 wrote:[quote:e66b5c3269=bd-850]i think its a waste, as you already have a Tacho and Temp gauge in the car so why need more[/quote:e66b5c3269] yeah well i would like to be able to see my trip meter and be bale to see my temp as well, and also i like the idea of the temp in C and not F, plus also it has volts and oil pressure all in the one unit, i like the idea of it or am i a tool for thinking it is a good idea
What is wrong with the Tacho already there???
Change your setup to have the temp as Celsius. If you have an oil pressure issue, the oil light will come on. If the car overheats it will alert you if you do not have the temp showing.
These cars have that many sensors to let the ECU know what is going on.
If you want something that is functional, get a scan gauge.
gordo37 wrote:[quote:41ddcd68d5=LZY_EYE]What is wrong with the Tacho already there???[/quote:41ddcd68d5] nothing, to start with all i really wanted was a water temp guage, but then i seen this as it is currently on sale for only 169 bucks and i thought having all the guages in one was a good idea
Scan Gauge is $200 and doesn't look ridiculous.
or if you have a android phone http://www.plxkiwi.com/kiwibluetooth/
or iPhone http://www.plxkiwi.com/kiwiwifi/
- gordo37
all my car has is a temp guage that shows a bar, and i don't have the mmcs, and how does a scan guage work, i have never heard of one.
EDIT: had a look at the links you posted, and they seem pretty cool, i already have a OBDII cable that i connect to my car using my laptop that tells me a lot of info, prob is, i don't want to have to have m,y laptop always connected
all the Lancers have a Bar temp gauge, anything over half and its getting hot (never seen that though)
The Scan Gauge plug into the OBDII port under the dash http://scangauge.com.au/
- gordo37
bd-850 wrote:all the Lancers have a Bar temp gauge, anything over half and its getting hot (never seen that though) The Scan Gauge plug into the OBDII port under the dash http://scangauge.com.au/
yeah they look pretty cool, thanks for suggesting it
- gordo37
Hoges wrote:Ive seen the Scan gauge on ebay for around $150.
oh ok sweet as
EDIT:
I had a talk to my Auto leaky and he told me that the tacho can't be hooked up to my motor, cause it has four outputs instead of one. and that they only way to hook the tacho up is to tap into the wires at the back of the Standard tacho, so i did not buy one, thnks for all your help guys, really love the help i can get from this site
thanks guys
GME TX 3600 UHF (80 UHF CH, Police, Fire programmed)- , Yaesu FT 857d HF Radio, ICOM ID-880h VHF/UHF Radio
- gordo37
EDITED: To fix spelling mistakes
Users browsing this forum: No registered users and 215 guests
