Can't Shift gear :(
SideWayz
Can't Shift gear :(
Postby SideWayz » Thu Sep 08, 2011 10:53 pm
Hey guys
i just had a problem, i turn my car on at train station car park drove it like less than 100m, i stopped i put it on Neutral and shift to gear one ( its Manual) and it won;t go in to any gear and i start to smell very weird smell soo i pushed it on the side of the road turn it off. after 5 minutes i put it on reverse and it just jumped and i could shift normal after that.
im still worried i don;t know what was wrong can any one please tell me what could be the problem?
its Lancer Vr 2009 and i have done 37ks
SideWayz
Postby SideWayz » Thu Sep 08, 2011 10:57 pm
ANd sorry guy i think i post this on the Wrong post
EVO X <3
Dire
Postby Dire » Fri Sep 09, 2011 12:26 am
It won't go into gear at all? And does it smell even when its just sitting there in neutral?
SideWayz
Postby SideWayz » Fri Sep 09, 2011 12:55 am
yeah it wouldn't go in any gear and there was some weird smell
turned it off and after 5 minutes it was fine
EVO X <3
DJBOOBY
Postby DJBOOBY » Fri Sep 09, 2011 5:38 am
sounds like the clutch to me
SideWayz
Postby SideWayz » Fri Sep 09, 2011 9:32 pm
u reckon something rong with it??? bad ?
EVO X <3
Postby bd-850 » Fri Sep 09, 2011 9:49 pm
Umm you can't get it in gear. It smells bad. YEAH there is something wrong. Is it bad. Umm YEAH.
I would ring road side assist. And get them to pick up the car
Sushi
Postby Sushi » Fri Sep 09, 2011 10:12 pm
clutch or maybe gearbox?
Dire
Postby Dire » Fri Sep 09, 2011 11:27 pm
I'm gonna go with stuck clutch.
Josh_Emerton
Postby Josh_Emerton » Sat Sep 10, 2011 1:24 am
The failure to change gear sounded like the gear shift cable bracket, under the battery area. I've had that unbolt on me before, thats the ONLY thing thats stopped me from changing gear. Ever. And I was the first CJ in Australia to blow the clutch >.< all it did then was extreme high revving no matter what and wierd smell, no gear change problems.
craigeth
Postby craigeth » Sat Sep 10, 2011 1:20 pm
Harry you're posting again! Haha.
www.twentythreeframes.com
SideWayz
Postby SideWayz » Sat Sep 10, 2011 1:42 pm
Ben i turned trhe car off for 5 minutes n turned it on and drove normally and its is still good till now its was 2 days ago
Josh but there was this smell aswell, when i turned it off and turn it on back after 5 minute it was going good
i donno wats going on :(
EVO X <3
Postby bd-850 » Sat Sep 10, 2011 6:24 pm
i would still take it to Mitsu and get it looked at
Postby aspir3 » Sat Sep 10, 2011 6:31 pm
I think this is a selector problem. It might have selected 2 gears therefore locking up the gearbox which caused the clutch to slip and burn.
I would definitely get Mitsubishi to check it out and demand the gearbox is removed for inspection and the clutch replaced. This should all be covered under warranty.
Users browsing this forum: No registered users and 99 guests
