So i was just on ebay and came across this - http://www.ebay.com.au/itm/15BHP-Power- ... 429wt_1141
has anyone heard about it or knows if its legit? seems really dodgy and its only 18.50
'Celox' boost bhp by 15bhp??
- Mr Charisma
eBay scam wrote:It will modify any standard ECU by telling the ECU that the incoming air in the intake system is cold and so advances the ignition by up to 2 degrees with more fuelling to compensate...
If you join as a premium member, you will be able to access the ECU Tuning section of this forum.
Many of us have been doing this for awhile now.
Real changes. Not some box... .
ofey wrote:[quote:3564454687=eBay scam]It will modify any standard ECU by telling the ECU that the incoming air in the intake system is cold and so advances the ignition by up to 2 degrees with more fuelling to compensate...[/quote:3564454687] If you join as a premium member, you will be able to access the ECU Tuning section of this forum. Many of us have been doing this for awhile now. [img:3564454687]http://www.clubcj.net/img/images/20110821104834_SparkMaps.jpg[/img:3564454687] Real changes. Not some box... .
Sorry to Hijack a little but whats needed to actually get started with that sorta stuff Ofey? because obviously thats the software but whats the hardware side of it like? expensive i take it?
Sorry and i wouldnt risk it... its not worth it and seems like absolute bull
@justin: the hardware is merely a tactrix open port 2.0 cable and a laptop PC running Windows XP or Windows 7.
