Hey guys, as you know I have a RX.
Would these fit into my car?
http://www.ebay.com.au/itm/Mitsubishi-L ... 1e66320d9c
http://www.ebay.com.au/itm/Mitsubishi-L ... 1e662beaab
P.S I will be getting the VRX Steering, so will the paddle shifter just plug and play? I would still need this right MI-8065A039XA COVER-STRING COLUMN-LWR(BLACK) ?
Would this fit into my lancer?
The paddle shifters should fit on any CVT, there is a guide in the DIY section somewhere, the vrx steering wheel is the same as the others from memory, and the instrument cluster should fit also, its all still the same car
EDIT: Paddle Shifters: http://clubcj.net/viewtopic.php?t=3284
If you don't want to cut your current lower steering column to fit the paddle shifters, yes you will need the lower steering column.
