Gearbox hesatation plus noise.
soniclancer
Postby soniclancer » Sat May 28, 2011 11:06 am
Ok only had the car few days and on warm up there is a noise that sounds like its coming from somewhere near the gearbox also when driving the gearbox seems to hesatate to shift gears also it goes from 2500rpm up to 3000rpm hold for a bit then starts to build up higher rpm not sure if this a normal thing for the ralliart lancer but i have it booked in monday to get checked out.Iam the second owner and car has had all it s services done.
Postby aspir3 » Sat May 28, 2011 11:31 am
Interesting, not sure what is the problem.
How many k's has the car travelled?
Did you buy it from a Mitsubishi dealer and is it under warranty?
Let us know the outcome please.
soniclancer
Postby soniclancer » Sat May 28, 2011 11:35 am
Car has done 53000km and is still under warranty till 2013 plus i took a extended warranty car was bought from lander Mitsubishi
Postby aspir3 » Sat May 28, 2011 11:39 am
You should have no issues getting this fixed under warranty then. This is good as SST transmissions are not cheap.
soniclancer
Postby soniclancer » Sat May 28, 2011 11:43 am
Will keep you guys informed hope its something simple
soniclancer
Postby soniclancer » Sat May 28, 2011 12:08 pm
Just been watching some videos on youtube mine doesnt shift anything like the cars on there.They were all nice smooth shifts no hesatation when changing through the gears with the cars i watched.
PYLee
Postby PYLee » Sat May 28, 2011 1:26 pm
does it go away after the car has warmed up ? Mine seems to shift funny when it's cold but is fine after warming up.
Though i've notice the SST shifting from 1st to 2nd is really slow compared to the rest , anyone else noticed ?
Lancer Evolution 10MR
R4LLI4RT
Postby R4LLI4RT » Sat May 28, 2011 4:01 pm
yeah mines the same, it shifts really strange up until the car has fully warmed up.
i dunno ive just hit 40,000km another 60,000 and ill probably get rid of it.
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
soniclancer
Postby soniclancer » Mon May 30, 2011 8:48 am
Ok just got back from the service department and they have found a fault with the gearbox and are now waiting on headoffice to get back to them on what to do been told the car is still ok to drive been told might take a day or two to get get back to me
soniclancer
Postby soniclancer » Wed Jun 01, 2011 6:07 pm
Update on gearbox drama i rang Lander Mitsubishi again today as ive not heard anything back from them about the repair go ahead was told that the headoffice gets busy at the end of the month with repair requests told it may take a day or two to get back to me i will give them till friday then going back to the dealership to see if i can get a straight answer
pjw1963
Postby pjw1963 » Wed Jun 01, 2011 7:26 pm
Hi there,
Mitsubishi sometimes can take up to a week or sometimes to get back to the dealer when problems like this occur.The Mitsu rep may need to drive your car before this repair goes ahead.
soniclancer
Postby soniclancer » Wed Jun 01, 2011 7:59 pm
Car was driven by a mechanic and they have said there is something wrong
just waiting to here back form HQ
soniclancer
Postby soniclancer » Fri Jun 03, 2011 1:51 pm
Update went and seen service department this morning and was told a replacement gearbox has been ordered just waiting for the call to book the car in was told should only take a day to replace
Dire
Postby Dire » Fri Jun 03, 2011 6:27 pm
Excellent outcome, I hope that doesn't cost you a cent. :)
