I broke it.
Mixedmotorsportmedia
I broke it.
Postby Mixedmotorsportmedia » Mon May 23, 2011 9:22 pm
hey guys, will keep it short n sweet for now lol,
i killed my motor haha... so time for the stroker to go in... dont know how or but what i thought to be a fudged spark plug turned out to be this.
Does not look like much. but also scored the block, that little bit of valve did its work on the block, going to check turbo soon to see if made its way through there lol
Andrew.
Postby aspir3 » Mon May 23, 2011 9:25 pm
That does not look good. So a faulty spark plug caused that.
It seems you are going to make the most of it though.
Postby Mixedmotorsportmedia » Mon May 23, 2011 9:29 pm
haha, nah i only thought it was s park plug.... but when i changed it nothing changed... then did comp test... 0 compression.... then was like FARK
Rob_RA
Postby Rob_RA » Mon May 23, 2011 9:46 pm
Mizta B
Postby Mizta B » Mon May 23, 2011 10:02 pm
OUCH!
Sorry to see that Andrew but could be a blessing in disguise?
Maybe you could build a stroker?
Let us know how you go mate
Cheers Chris. :D
Merlinised....
Slash
Postby Slash » Mon May 23, 2011 11:35 pm
Jun stroker.. do it.. would love to see how it performs.
Dire
Postby Dire » Tue May 24, 2011 12:39 am
Shouldn't your warranty still be good or is this your fault? :P
Slash
Postby Slash » Tue May 24, 2011 8:48 am
Not if the drive train has been modified... so its his fault! :P
Tooo much powar~!! :D
shamrockshirts
Postby shamrockshirts » Wed May 25, 2011 3:33 pm
What was the cause mate?
El-Diablo
Postby El-Diablo » Sat May 28, 2011 1:10 pm
Go the Cosworth kit. It even has proper conrods :twisted: You will probably need to go a sleeved block as well
El-Diablo
Postby El-Diablo » Sat May 28, 2011 1:25 pm
what condition was the spark plug and what cylinder was it? Ive heard of number 4 cylinder sparkplugs striking piston top then causing failure in the states.
Postby Mixedmotorsportmedia » Sat May 28, 2011 4:28 pm
lol thats the case mate, number 4 and the sparkplug was fucked :P
Rob_RA
Postby Rob_RA » Sat May 28, 2011 5:45 pm
Any damage anywhere else or just number 4? Were you still using factory plugs?
El-Diablo
Postby El-Diablo » Sat May 28, 2011 7:03 pm
Might be worth a talk to mitsubishi if this was a known fault you'd probably have a claim.
IE if a batch of heads had the number four sparkplug thread faced to deep allowing the plug to come in contact with the piston.
shamrockshirts
Postby shamrockshirts » Sun May 29, 2011 10:00 am
Still can't get my head around this no.4 hitting the sparkplug story. Surely if its going to hit it will hit the sparkplug on the 1st revolution the engine ever makes (i.e. at the factory).
Does anyone know the details or what the other circumstances/conditions that they claim causes it?
Cheers
John
