F.S pedders 14mm camber bolts $45
whitenight
Postby whitenight » Sat May 21, 2011 3:20 pm
ITEM: pedders 14mm camber bolts (front)
ITEM CONDITION: new
REASON FOR SELLING: dont fit bc coilovers
PRICE AND PAYMENT CONDITIONS: $45
SHIPPING AND POSTAL ARRANGEMENTS: free
EXTRA INFO: good for xtra camber or 0 camber if lowered
CONTACT INFO: pm or post
PICTURES: Image
Evo Mike
Postby Evo Mike » Sat Jun 04, 2011 10:21 pm
hey white knight, all i had to do was get out the metal file and take some edge off the inside of the coilover hole, mine were a bit tight at first, just make sure you can slide them in and out while still maintaining a relitivly tight fitment
Postby aspir3 » Sat Jun 04, 2011 10:27 pm
Mike they did not fit because the coilovers have a slotted hole which allows for camber adjustment. When the camber bolt was fitted when you turn it it does nothing.
Evo Mike
Postby Evo Mike » Wed Jun 08, 2011 4:02 pm
ahhhh ok, i just presumed it would be the same for all coilovers, mine in mt celica gt4 were slightly too tight so just had to take out a tiny bit from the slotted hole to make them fit
Evo Mike
Postby Evo Mike » Wed Jun 08, 2011 4:04 pm
note to self, when doing this make sure you spray with inside of where u just filed down, or u might get rust under there
whitenight
Postby whitenight » Tue Jun 21, 2011 4:50 pm
bump (price drop)
